What can I safely build with a 50VA transformer?
Hey there, I grabbed a pair of industrial control transformers a little while back-
http://www.diyaudio.com/forums/tubes-valves/287544-480vct-50va-less-than-12-shipped.html
NEW RIB Functional Devices Transformer TR50VA018 T-249 NIB | eBay
And figured they would be at least worth the fuss of fooling around with. Using them backwards (feed them from the 120 side, and rectify the 480VCT side) in a center-tapped FWB with a pair of beefy diodes, and a couple of spare 12.6VCT 2.5A transformers on hand should be pretty affordable and cheap.
What can I safely consider these to be able to continuously supply for DC current? They seem very well made, but I'm not too keen on stressing them out too much. Would I be safe in using a single one to supply a stereo AB1 pentode/tetrode connected design using 6V6 or EL84?
50VA @ 240Vac is 208mAac
Converting that to DC would make a continuous 110mAdc available. This is the maximum continuous and likely to make the transformer run pretty hot.
For cool running reduce to ~50%, i.e. 50mAdc to 60mAdc continuous @ ~320 to 340Vdc
50VA / 480V = 104mA rms
In a typical amp the power factor is likely to be around 0.65, so your maximum safe DC current is: 104 * 0.65 = 68mA dc. Obviously you'd want to derate that a bit for longevity.
A pair of EL84s will be uncomfortably close to that limit if you bias them at a typical 25mA each, since the average current rises in a class AB amp under signal conditions. But if they're overbuilt transformers then maybe you'll get away with it, if you keep preamp current demands low.
Hmmm. Maybe a pair of monoblocks biased a little lean might be the ticket then. I'll just be using a basic capacitor input PSU, and maybe a Maida regulator for the screens, which is simple enough to lash up a single reg per output pair anyway. I might have to lash something up and see how warm it gets at a lean bias current. The preamp is likely to be a 6sl7 concertina, so pretty lax current demand there.
I would not worry about loading-up a "control" transformer: they sometimes work 24/7 at full load in business-critical applications.
Except I never hear of "RIB" brand??
AC to DC conversion is hard on a transformer. Derate by 1.6 at least. So you can suck around 30W of DC.
6V6/EL84 are good for 12W of dissipation each, and are not typically run far into class B where power input rises. Counting screen, bias, and filtering, say each bottle can eat 14W. Plus <1W for driver. So you can run two power bottles and a little bottle. Stereo 5W audio out, or mono 14W audio out.
And a heater transformer on the side.
Wow, couldn't find the thread, but I suppose this is a better place for it.
So, I'm thinking with 6v6 or el84 I should be fine running a single transformer for stereo SE (ew, gross 🙄) or as one channel each push-pull. Somehow I've never actually built monoblocks, so that sounds like a fun idea, one on either end of the workbench in the garage would be handy.
