What do you recommend for multimeter test leads?
I just recommended these the other day in another thread
They are excellent , spring loaded spike , and very very very sharp, you will never slip off a solder land ever again
Hirschmann 972318100
MX here used to sell kits, with threaded connectors on both sides, you got two sets of normal probes, crocodile clips, lugs and something else I don't remember..
Got it years back.
Other set is one with wires you can solder, and a piggyback system, I can connect another set of probes to the back of the ones in circuit, useful if two meters are in use.
If you are into low voltage / mains, just get ordinary thick wire probes you can repair by soldering, as that is the place wires fail, by flexing, thick wire lasts longer.
Those probes are about 60 cents here.
Or buy a bunch from surplus mil grade...those should be good, only the meter socket must match.
For high voltages, be very fussy.
Fluke or Probemaster work fine. The price you pay is for good materials (longevity and safety) and accuracy (precision and repeatability) in readings and you get what you pay for.
I was given a pair of leads and a cheap DMM by a friend's father as a thank you gift for repairing their old Sansui amp (electrolytic capacitor replacements) as he wasn't doing electronics anymore. I got home, tested the leads for the sake of testing them, and got a reading of about 1.5 Ohms touching them together. That would have added inaccuracies in my measurements either sorting components or looking for problems and probably would have been even more inaccurate measuring current as they heated up (this could be an issue in the Passdiy stuff and maybe not so much the tube stuff).
Not worth it. I tossed the leads and kept the DMM for sacrificial testing around the house and car.
The key requirement for leads I have is they can handle being used on the 10A current setting, and many probes have thin wires - even those Fluke one's have a blank datasheet (!) so how do you know they are any good for high current?
I have made my own in fact using generous gauge high flexibility silicone insulated wire and small croc clips (sold for RC models) - you know its happy with 10A+ then...
You know they’re good for 10A because they’re sold with their meters, which have a 10A range and are respected meters. They’re also good for 1000V.
If you’re only working with extra low voltage (60V or less) often banana leads are a better choice than test leads. Pomona do especially good ones. They also do good quality alligator clips that go on the end of a banana lead.
Stacking Banana Plug Patch Cord, Gold-Plated | Pomona Electronics
Alligator Clip With Banana Jack | Pomona Electronics
