Just bought one of these! Yes, it's stereo, not mono. $6! Free shipping!
Why not?![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Promotion TDA7297 Whi Fi Noiseless 2 0 Audio Power Amplifier Board Max 30W 30W | eBay
Why not?
This is a BTL class AB/B amp, not class D, note the lack of output inductors.
Well, you'll have to educate me on what qualifies as a class D. And for that matter a "chip amp".
I don't think I know the difference really.
I have a Jerry's Electronics Amp too, and a Sure. I don't think there's inductors on either of those.
Mark
Mark
Wikipedia can explain better and takes less time to type: Amplifier - Wikipedia, the free encyclopedia
Data sheet here:
http://www.st.com/web/en/resource/technical/document/datasheet/CD00001048.pdf
16.5V 8R 2 ch 15W ea @ 10% thd
18V 8R 2 ch 14W @ 1% thd
You will need more heat sink.
Mark
Jerry's is tpa3122 which is a class D and has inductors (ferrite core with wire around them, vertical deals). Small Sure 8 w board gets away with tiny ferrite bead as inductor. Bigger Sures have surface mount inductors that look like a black cube.
Class D is a pulse width modulation switching amp where the power transistor swings from on to off at switching freq usually 400 khz or up. The duration of how long it switches on controls amplitude and inductor and capacitor at output filter out the fast switching transients.
Note in the diagram from Ebay it shows a 12V+ voltage and a corresponding 12V- this is a technical error. It is not a split supply.....the supplied instruction manual should clarify this....consult the datasheet that is posted here.
Don't expect true quality sound from this.....I heard somewhere that all other things equal, humans can detect THD levels above 0.5 .....this limits the bulk of the power output( >1W) above this level.
___________________________________________________Rick.......
Good point. I think they meant 12V supply positive and supply negative but it could easily cause confusion. And yes, the chip's datasheet specs aren't very exciting.
The good news (besides the astonishing price) is the included heat sink can probably handle that 1W output.
I admit I'm still wondering what Whi-fi is.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Anyone agree that this thread should probably be moved to the Chip Amp forum?
Stay tuned
Hi everyone,
I will let you know if this is a thumbs up or thumbs down when it arrives.
I read the Wikipedia article. I still don't think I could tell you the difference between a chip amp and class D. It's beyond my scope right now -- and 56 year old brain maybe.
Tubes, solid state, and "the rest" is how I classify it. I've heard good and bad in all three.
Hope this one is good. And you guys all buy one before they raise the price.
You just never know what cheap and good thing you may happen across. I won't dismiss it with a data sheet. When I hear it, I'll decide then.
Remember, on the bumblebees data sheet. They cannot possibly fly. Theory vs. reality.
Mark
Hi everyone,
![shhh :shhh: :shhh:](https://files.diyaudio.com/forums/images/smilies/shhh.gif)
Mark
its a pretty fundamental operational difference. Class D relies on a fixed and hard switching carrier frequency (can be analogue driven free running or driven by a clock) that is much higher in frequency than the audio. a pulse width modulator (PWM) is imposed over this to create the audio. normal A or AB has frequency and amplitude modulation, but no carrier. then there are the technological differences; but it has nothing to do with D standing for digital, because it doesnt, D just comes after C, which came after B which came after A...
yeah the bumblebee thing is a myth that simply wont go away
Often this bumblebee story is used to discredit scientific conclusions about the impossible nature of supernatural events or feats.
Mark
Actually it has been proven that they can fly and how. The hypothesis that it has at any time even been discussed in science that they couldn't is inane non-sense as is often the case with urban myths.
There's no "other stuff". There's just tubes and transistors. Class A, AB, D or whatever can be made with either.
Not sure why someone is saying power output is limited to 1 watt? That heatsink looks like at least a 10 watt heatsink. Class AB is about 50% efficient so I would guess closer to 10 watts output.
Off topic but not only can the bumblebee fly, it is scientific fact measured in the lab that as an engine and locomotive system, the bumblebee is super super efficient. Based on calories in honey and distance the bee flies, and converting the calories to energy content equivalent in gasoline... the bumblebee gets 4.7 million miles a gallon!
Here is article on flight of bumblebee and its aerodynamics:
Flight Of The Bumble Bee Is Based More On Brute Force Than Aerodynamic Efficiency
Here is article on fuel efficiency of bumblebee:
Bee Vs. Car: Who Gets More Miles Per Gallon? : Krulwich Wonders... : NPR
64 kilometers per bellyfull
Bee Vs. Car: Who Gets More Miles Per Gallon? : Krulwich Wonders... : NPR[/QUOTE]
Very cool, X!
Makes my Jetta TDi look like a guzzler!
Mark
Very cool, X!
Mark
I'd be surprised if you can find a class AB amp that is more than 30% efficient with music signal. The TDA7297 as used here is in fact only 20% efficient like most class AB amp (it's the efficiency at 10% of peak output you need to look at).
no its not super efficient, well not by insect standards. the first article about bee miles per gallon is for standard honey bees, not bumble bees. Bumblebees as the second article says, have a disconnect between their left and right sides. this feature allows them higher maneuverability in a controlled stall/hover, but means they cannot leverage the energy/efficiency of combined vortices around the body in forward flight. its brute force, the honey bee is much more efficient.
- Chip Amps
- What the heck? It's less than lunch!
