What type of magnifier to use for soldering?
I tried using a bench/freestanding magnifier. It drove me crazy because it always seemed to be in my way.
Maybe its me and my lack of organization.
I’ve used a cheap jeweler’s loop with a couple of flip down lenses that clips onto my glasses with more success.
https://www.amazon.com/Jewellers-St...cphy=9003229&hvtargid=pla-2334223444681&psc=1
I don’t really do SMD for the most part…a few parts here and there.
It gets the job done.
Reactions: plasnu
As being a cycope, a simple eyepiece suffices.
Amplification may vary.
Reactions: plasnu
Like the OP I am also interested in magnifier lights and in my case lighting in general, I have visors (with lights) and loops and don't like microscopes. I have an ancient magnifier lamp 2.5X magnification which I would like to replace. I do a lot of SMD and very little else. I wear prescription glasses at my bench (several different magnifications).
Reactions: plasnu
For head mounted magnifiers, this one is very good with better optics than most, and lots of good ratings: https://www.amazon.com/dp/B007CDJKM2?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_7
The next step after that is a long working distance stereoscope optical (non-digital) microscope. This is a good yet pretty low cost one in that class: https://www.amazon.com/AmScope-SE400X-Professional-Microscope-Magnification/dp/B0056X4RRS/ref=sr_1_16?crid=AEVLPL75ERRP&dib=eyJ2IjoiMSJ9.SR43ihCGWgQg1LCTdCtM1TWKTZut2lvycSYk4IioL1FWqE4MRgz3KquTYSjvNQdhkxxKAP8eYHudffFcpVlXqZjbmrEhHEG5tqeZvmmEpRiFu-JOQYbVOadUmzrr2RgB_fLFbQVdI6pybftOAUr__QuQZg6Xk7QJHmaalHnNpw6I6EzaEh-39Urw63QUwspt_zMeqBVyX70anWQ0tshiTD7JidzOWAycbL6VAZYDmLs.DRfWJCcXVirBY-wn0e5erYbgrVfWDMvFr6UiasYSUUs&dib_tag=se&keywords=amscope+stereo+soldering+microscope&qid=1744397581&sprefix=amscope+stereo+soldering+microscope,aps,150&sr=8-16
Either way, stereoscopic vision greatly improves hand-eye coordination. That's the main reason for avoiding digital magnifiers, as they are 2-D and thus give poor depth perception.
I'm a jeweller (and hobby solderer) and use (in order of most often to least)
1) Optivisor DA3. 2) Ring-light with central magnifier. 3) Nikon Stereo Dissecting Microscope - (with Bowman 0.5x reducer lens to give a better field of view.)
However, what makes more difference to view and control is lighting..lighting..lighting!
I use Anglepoise lights with the strongest LED bulb they will accommodate and get them as near as possible to the work without impeding access.
When needed I will use more than 1 and even up to 3 to provide the best possible shadow-free illumination and thus accurate positioning of the 'little pointy bits' that do the work
https://www.anglepoise.com/
https://microscopecentral.com/products/nikon-smz-1-stereo-microscope
https://doneganoptical.com/product/optivisor/
These all use proper ground glass lens... not nasty last a month plastic!
For really close inspection (not working) I have several loupes but generally just flip down the Optivisor loupe.
https://doneganoptical.com/product/optiloupe/
Yes! Lighting is crucial. You need lots of it. The more light you have, the tighter your pupil can close, giving you a sharper image (just like using f/22 on a camera instead of f/4). Sometimes, (when drilling) you need a really harsh light from a point source that throws up shadows, other times, you want a diffuse light. I have made lamps by fitting 3W downlighter LEDs on the end of goosenecks on a magnetic base; they allow me to put the light source 100mm away if needed. I used to use Anglepoise lamps but the home-made lamps are brighter and far less bulky, so the Anglepoises went to the charity shop. Likewise, for some stuff, a stereo microscope is needed. I went for a cheapy microscope, then fitted it with an XY table and one cross-haired eyepiece. That enables me to measure awkward dimensions accurately using the graduations on the table. One of these days, I'll get round to fitting the table with digital readout.
