Wow, this is a great forum topic. Very inspiring! I've been looking to get into building amps for my home theater and 2 channels. It looks like it would be a lot of fun.
Is there a sort of beginners guide to it all? I've looked throughout this site and have tried to make sense of it but nothing has quite clicked in my head completely.
There seems to be a lot of guides for tube amps where they break down how a tube amp actually works as well as how to make decisions on what parts to use etc but the equivalent doesn't seem to be as available for solid state.
I really want to learn about building solid state amps so thanks in advance!
Q: Is it cheaper to make a high end amp as opposed to getting one from a high end manufacturer?
A: Building a high-end amplifier (whatever high end may mean) is generally cheaper than buying one. Many high-end manufacturers produce equipment in rather limited numbers and need to make their selling prices high to stay in business.
Places to purchase a kit:
Akitika Preamp and Power Amp KitsElliott Sound Products - The Audio Pages (Main Index)
Books and online information to read:
Leach Amp Plans
Leach Amp Plans - Part 1
Decibel Dungeon
Index page for Decibel Dungeon, a DIY hi-fi site for hi-fi lovers.
Nelson Pass:
https://www.passdiy.com/
Solid State Amplifiers: John Burnett:
http://http://education.lenardaudio.com/en/12_amps.html
Douglas Self
Robot Check
Robot Check
Bob Cordell:
Robot Check
(German) Tietze Schenk - Schaltungstechnik has a chapter on power amplifiers
Halbleiter-Schaltungstechnik: Amazon.de: Ulrich Tietze, Christoph Schenk, E. Gamm: Bcher
Bailey: 30-watt High Fidelity Amplifier
http://www.keith-snook.info/wireless-world-magazine/Wireless-World-1968/30-Watt%20High%20Fidelity%20Amplifier.pdf
Stuart: An approach to audio amplifier design
http://www.keith-snook.info/wireles...973/An approach to audio amplifier design.pdf
Newnes: Audio Engineering - know it all
Robot Check
Duncan: High Performance Audio Power Amplifiers
Robot Check
Louis Frenzel: Crash Course Electronics
http://www.amazon.com/Course-Electronics-Technology-Second-Edition/dp/0750697105
Harry Kybett: All New Electronics
http://www.amazon.com/Electronics-Self-Teaching-Guides-Kybett-2008-05-12/dp/B019NDHXSQ
Videos:
https://www.youtube.com/watch?v=YuVqccvgNPM&feature=youtu.be
Leach Amp Plans
Decibel Dungeon
Nelson Pass:
Douglas Self
Robot Check
Robot Check
Bob Cordell:
Robot Check
Robot Check
Robot Check
Videos:
I'm afraid that without an education, we are just paint by number artists. Busy yourself playing with blocks. Kits, that is. There are some very good ones. By guys better than you or I will ever be.
Do you want to learn how to build one (learn how to solder and how to read schematics) or do you want to learn how to design one? In the first case a kit would be a good starting point, in the second case start with studying the basic rules of electricity, then network theory, then basic electronics, then read a book about audio power amplifiers.
One nice feature about tube amplifiers is that quite simple amplifiers often sound good, even if their measured performance is only so-so.
Thanks for the info. If you guys have any links to good material, I can edit them into the first post. I've soldered before. I'll read up on that. I think a kit would be better for me. I've studied basic electrical electrical, haven't studied network theory or basic electronics. I'm going to look into those and see if I can find some good info on them.
Buy the book by Douglas Self,
Audio Power Amplifier Design 6th Edition
Audio Power Amplifier Design: Douglas Self: 9780240526133: Amazon.com: Books
Lots of info and inspiration found in there.
Good books are:
- Bob Cordell: Designing Audio Power Amplifiers
- Douglas Self: Audio Power Design Handbook
Both authors are here on diyaudio.com
For the german speaking people "Tietze Schenk - Schaltungstechnik" has a chapter on power amplifiers too.
Shorter Readings:
Stuart: An approach to audio amplifi er design
Shorter Readings:
A solid state amp is usually made of modules.
Like long tailed pair, current mirror, current source, voltage amplifier stage, Vbe multiplier, driver, feedback and output stage.
Learn how each works on its own then try to put it all together to understand the whole amplifier.
Nelson Pass has written some great information about simple circuits and how to learn from them, along the lines of what nigelwright7557 is talking about. Most of us start on a kit and, if the bug bites, keep going. The kits at the forum store might be a place to start. You've got a lot of backup here. In any case, it's fun. Regards, HeyBill
Spend lots of hours and weeks reading this site for everything you didn't know but wish you did. It costs only the ISP data rates. Note also the links to the Lenard learning site for the basics in simplified, easily followed format.
Amplifiers: Solid state amplifiers
Nigel, I'll keep an eye out for that stuff when I get to reading.
Heybill, I pulled up hjs site and put it up top.
Ian, Good links, I added them in and will go through them.
I'm going to do a lot of reading but I plan to get a couple of speakers from DIYsound group and build a couple of amps based of something like the Gaineclone.
Thanks guys.
Thanks guys.
Btw, looking at your homepage I could neither discover an address nor a phone number. Did I miss it?
Elliot sound homepage was last updated 2008 - I suspect he retired meanwhile.
there is a link, near the bottom of the page, into your EmailBtw, looking at your homepage I could neither discover an address nor a phone number. Did I miss it?
ESP is still active and still updating old articles and adding new.Elliot sound homepage was last updated 2008 - I suspect he retired meanwhile.
Add Decibel Dungeon to the recommended reading list.
- Where to Learn About Building Solid State Amps?
