I have been looking at a number of soft start boards on Aliexpress, Ebay, etc., and wonder if any of them are any good, if there is a "better" one,
From Connex Electronic, Power Soft Start v3,
https://connexelectronic.com/product/power-soft-start-v3/
Yuan-Jing Soft Start Module (110V / 220V) w/ Thermal Protection, Product Code: FNB-POW-SB-001,
https://www.yuan-jing.com/soft-start-module-110v-220v-w-thermal-protection
Lusya 2000W Amplifier Power Supply Soft Starting Board 100A High-current Relay For class A Audio Amplifier board AC220V or AC110V G1-006
https://www.aliexpress.com/item/32998344730.html
GZLOZONE POWER-S.S Class A power amplifier high current power supply delay soft start DIY Kit 20A 110V/220V optional
https://www.aliexpress.com/item/32813795278.html
Power Supply Soft Start Board For Super Power Amplifier Bingzi Transformer AC110V AC220V
https://www.aliexpress.com/item/1005006389308823.html
Also open to suggestions for Soft Start options.
I have several A/B amps I would like to build that have large'ish toroidal transformers and cap banks behind them. Specifically Nelson Pass AB100 and DiyAudio Wolverine amps.
Largest concern is not welding a switch turning turn on/off.
https://www.aliexpress.com/item/4000124711665.html
I am using it just for two months, no issues so far.
Thermal sensors are usually needed in amplifiers.
