Which capacitor?
I get a good deal through work with RSwww and I want to buy come capacitors for some solid sate and chip amplifiers, but I am confused by choice. For example the following list comes up for 10uF capacitors 50-63v. Which would be the best for audio? The first bit is a short description and the longer alpha-numeric number a bit later is the manufacturers part number.
Many thanks.
Simple.
365-4240
NHG min Al electrolytic cap,10uF 50V Panasonic ECA1HHG100 Al electrolytic cap,PS,63V,10uF
519-4396
Al electrolytic cap,PS,63V,10uF Nichicon UPS1J100MDD FC radial elec cap,10uF 50V
315-0805
FC radial elec cap,10uF 50V Panasonic EEUFC1H100 Al electrolytic cap,PS,50V,10uF
519-4289
Al electrolytic cap,PS,50V,10uF Nichicon UPS1H100MDD YXF Al electro cap,10uF 50V 105deg C
224-4325
YXF Al electro cap,10uF 50V 105deg C 50YXF10M5X11 Al electrolytic cap,PM,63V,10uF
520-1545
Al electrolytic cap,PM,63V,10uF Nichicon UPM1J100MDD YXF Al electro cap,10uF 63V 105deg C
191-7892
YXF Al electro cap,10uF 63V 105deg C 63YXF10M5X11 LXY Aluminium Capacitor,63V,10uF
547-8701
LXY Aluminium Capacitor,63V,10uF Nippon Chemi-Con ELXY630ELL100MEB5D FC radial elec cap 10uF 50V
571-256
FC radial elec cap 10uF 50V Panasonic EEUFC1H100L GA Al electrolytic cap,10uF 50V
414-9187
GA Al electrolytic cap,10uF 50V Panasonic EEAGA1H100 116 RLL Aluminium Radial Cap,50V,10uF
230-4821
116 RLL Aluminium Radial Cap,50V,10uF Vishay MAL211651109E3
In 10 uf 63 v I don't buy electrolytic caps anymore, I buy film dielectric. Lasts a lot longer and you don't have to worry about eliminating negative voltage. I put a bunch of polyester and polystyene caps in my organ last year. You can see the size if you click the link to the manufacturer's website on the order page.
Pull up the data sheets for each particular series ie NHG , FC , etc
Some caps spec ESR out to 100KHz and 105*C . Look at case size and voltage rating for the actual #'s. Those are the good ones ie traceable specs and long life MTBF.
