I'm upgrading a class ab amp ( from active 2 way monitors- event opals) that has some caps in the signal path
* see attached schematic- output goes to input of first stage of amp
1.0uf 63v film cap for tweeter
100uf 25v non polar/ bi polar electrolytic cap for woofer
and also, in parallel with the 100uf, a 0.1uf 250v film cap for woofer
the oem caps are all around 10 years old, and all no name/ low grade
with a small budget, and very limited physical space to mount caps, what caps should i consider that may provide smooth and
clear highs (metal dome seas), and smooth and clear mids and lows ?
in my inventory, that im considering using, i have some 1.0 uf multicaps ( ppfxs, ppmfx, ppmf), nichicon fg 100uf (polar), nichicon 100uf es (bipolar),
and 0.1 uf film caps ( small blue cubes, * possibly mkp 1837 vishay ?)
