Which KEF B200 is best?
Looking at the spec sheets which can be found here my guess is SP1054, am I right? Does it make a big difference??
Which B200 is "best" will depend on your application, i.e., your intended enclosure.
For example, the small magnet SP1014 was used in the compact infinite baffle KEF Chorale speakers, while the large magnet SP1039 was used in the larger ABR loaded KEF 104 and 104aB models.
Reactions: Budatone
That snapshot looks to be from my site: Those data sheets were scanned from the KEF blue binder i got from KEF. That predates the 3 screw B200, which isn’t really much the same.
As Galu suggests it depends on your application.
I do question SP1014 in small oxes (i have heard some and they sound good (Tangent TM-3), but i have 16 of them and modeling suggests a MUCH larger box required.
Note that other than the SP1014, none of the others were available to diyers so are much harder to find.
dave
Reactions: Budatone
Thanks a lot Dave and Galu, I appreciate it!
So Dave, are you saying SP1014 might work well in a 2 cu ft reflex enclosure? Could you also explain why SP1022 and SP1054 both say 50L but have different cu ft values please? I'm inclined towards SP1054 for the lower Q (low is better, right? Or is that an oversimplification? Which would you choose? Sorry for the noob questions..
P.S. Thank you so much for uploading the spec sheets in the first place and sorry I didn't credit you in my initial post.
Thanks a lot Dave.
It's a bit of a change of subject but I'm guessing you're into Transmission Line speakers? I recently got a pair of IMF ALS30s - they are Active Line rather than Transmission Lines but I thought you might be interested.
Strange, there seems to be a mistake in conversion regarding the SP1054.
Assuming the litre values to be correct, its reflex cubic foot values are incorrectly calculated and should be 1.4 (40 L) and 1.8 (50L).
EDIT: And the SP1022 delights in stretching 1.8 cu ft (50 L) to 2.0 cu ft!
Reactions: Inductor
Thanks Dave - I was specifically setting out to build a BC1-style 8” driver in a 2 cubic foot vented box.
I saw a Graham Audio LS8 in a shop and loved it but can’t afford it, so I went home and started reading about the history of the BBC Research Department and thin wall cabinets, bextrene cones, Spendor, Rogers, Harbeth etc. and decided to learn how to build my own. I’m clearly not quite there yet and I appreciate all the help you’re giving me, but it’s got to be a 24”x12” reflex enclosure, nothing else will do.
That’s a shame, I thought I was getting somewhere! How would I go about finding a suitable 8” mid-bass for a ~2 cu for reflex enclosure then? I’m not asking you to do the work for me - is there a good resource that you know to help a beginner like me understand all this stuff? Thanks again.
Why? The B200 sealed goes lower and has a lower order roll-off. But if you find that the bass lift at the bottom is too much you can add an aperiodic vent to work towards flattening it out.
If you have B200 already, try it.
If you have to have a reflex, I know of no other way than picking all the 8” you find interesting, that are within your budget and plug them into a simulator and se if you can come up with a decent alignment.
dave
