Windows 10 up-mixing
Moderator
Joined 2004
Is anyone here doing upmixing in Windows 10? In theory it's possible to up-mix 2 channel stereo to 4, 5.1 or more channels in Windows 7,8,10 but I have not been able to get it to work. "Speaker Fill" is the normal enhancement that Windows should use for the up-mix when the system has a multi-channel card.
Chrome has some switches for audio routing that I've tried, but no luck so far. So not sure if it's browser related, or Windows.
The reason to use it is simple, to get standard stereo mixes into a Quad or surround system. A Pro Logic II type decoding built into the OS.
