WinISD Alternatives
I am using WinISD to run box alignment sims for different woofers and it's not going so smoothly. I add drivers parameters (for drivers not in the db) and I always get integrity problems even though I copy them off the manufacturers data sheet. Is there an easier program to use?
I no longer have the list of ones with errors that I emailed about to no avail and didn't bother to list some more before giving up, so can only say 'caveat emptor' applies in my experience. 🙁
oh that's a shame. i never had a conflict when using them so I figured it was OK. thanks for the heads up
WinIsd has its ups and downs but it is a reason I eventually liked the sum check /integrity function.
You can cross calculate unknown parameters for certain drivers, or be sure your not
using wrong parameters all together.
Eventually over time when you understand what the parameters are.
It wont be a issue.
This is a very common issue with many being new to the program.
Also part of the learning curve. Not only speaker simulation , but
understanding electrical and mechanical aspects of drivers
and how they relate.
It helps to enter parameters and only certain parameters in certain orders.
then let the others cross calculate.
Then you wont get errors.
Suggested order for parameters.
Thiele / Small.
1) Qes
2) Qms
3) Fs
4) Vas
5) Qts =will auto calculate, dont enter
Electro Mechanical.
1) Re
2) Sd
3) Le
4) Mms , Cms, Rms , BL= will auto calculate, dont enter
Large Signal.
large signal will not cause conflictions.
enter Xmax and RMS Thermal Rating or Pe in watts
Reactions: jimbones
