Wire colors for dual-rail power supplies?
I'm curious what wire colors folks like to use with dual rail power supplies, such as +/-15Vdc.
For house wiring (in the US) the line/phase (hot) is black, neutral is white, and earth ground is green or bare.
For single-rail electronics red is positive and black/ground is negative.
So then, for dual-rail electronics:
  • Positive rail = ?
  • Negative rail = ?
  • Circuit ground (between the two supplies) = ?
  • Chassis ground, if different from circuit ground = ?
I've typically used red for the positive, black for the negative, white or yellow for the circuit ground, and green for the chassis ground if the need arises. I'm especially curious what color folks use for the circuit ground here. 🙂
What brought up the question? I'm getting ready to order a bunch of wire. 🙂
If I was buying wire off a spool it would be red/black/yellow (or white, blue or green for negative).
Sometimes though you strip a few strands off a ribbon cable. then I use the VIBGYOR system, the middle wire is ground and whichever wire colour has shorter wavelength (of reflected light) becomes the positive. Hence I'll end up with funny combos like brown/black/purple or similar.
Hey a big thanks to everyone for the comments! Gives me a lot to consider. 🙂 Definitely a lot of variation in standards around the world.
tomchr - you have a good point there, I hadn't thought about that. With red as V+ and black as 0V/ground, the "positive half" colors of the dual-rail supply would match up with single-rail colors.
I currently use AC cable NYYHY made by local company, it will refer to below colour:
L : Brown
N : Blue
E : Yellow/green stripe
This will also match with transformer primary cable colour which has Brown and Blue colour.
While for DC, below scheme can be used ( red and black seems commonly use)
+ : Red
- : Black
G : Yellow
which ever colour shceme that you use, just remember not to mix them
This is a practical interesting question!
I was scratching my head over it yesterday. The battery terminals are red for positive black for negative. For test driving a op-amp headphone amplifier I put two 12 volt gell cells in series. For negative 12 volts I connected to the black terminal of the first battery with black insulated wire. For positive 12 volts I used red insulated wire to connect to to the red terminal of the second battery. I used yellow insulated wire to connect to to the common in the center of all of that.
So red is positive 12 volts, black is negative 12 volts and yellow is common.
Your millage may vary.
DT
L : Brown
N : Blue
+ : Red
- : Black
G : Yellow
DT
Mains wiring is Brown, Blue, Green/Yellow
Low voltage DC wiring is Red, Yellow, Black.
No confusion.
Instantly recognisable which (mains ,or low voltage) one is looking at.
