An integrated amp based on the Dynaco Pat-4 preamp and the ST-80 (Stereo 80)power amplifier. Fully functional and ready for refurb and mods. A great starting point in that it's complete and working with surprisingly little hum though I'm sure the electrolytics are tired.
I had planned to do a variety of mods and refurb the unit for my daughter. She took a tube route so this baby is sitting around collecting dust. It needs to good home and an owner to make it sing. If you're unfamiliar there are loads up upgrades and mods to pursue.
Front panel is pretty clean except for a small mark in the center. With a bead blast and paint job, the will be better than new. Controls and connectors need some cleaning as expected.
$100 plus actual shipping plus 3% paypal.
Specifications:
Rated Power Output: 30 watts continuous average power per channel into 8 ohms, 20-20,000 Hz at less than 0.5% total harmonic distortion. Distortion decreases at lower power levels.
Power at Clipping, Single Channel, 1000 Hz, less than 1% distortion: 50 watts @ 8 ohms, 36 watts @ 4 ohms, 26 watts @ 16 ohms.
Intermodulation Distortion: Less than 0.5% at any power level up to 40 watts rms per channel into 8 ohms with any combination of test frequencies. Distortion reduces at lower power levels.
Half-Power Bandwidth: 20 watts per channel at less than 0.5% total harmonic distortion from 8 Hz to 50 KHz into 8 ohms.
Frequency Response:
Phono: ± 1 dB of RIAA curve @ 1 watt into 8 ohms.
High level: ±0.5 dB, 15 Hz to 50 KHz @ 1 watt into 8 ohms.
Hum and Noise:
Phono: More than 60 dB below 40 watts output.
High level: More than 80 dB below 40 watts output.
Input Sensitivity: 100,000 ohm load; 1.3 volts for 40 watts into 8 ohms.
Impedances:
Magnetic Phono: 47,000 ohms.
High Level: 100,000 ohm.
Tape Output:
From Phono inputs, 10,000 ohms minimum load.
From High Level inputs, same as source.
Headphone Output: 8 ohms or greater.
Phono Input Overload: 80 mV @ 1000 Hz.
Tone Controls:
± 12 dB @ 50 Hz;
± 12 dB @ 10 KHz.
Separation: 65 dB by IHF standards.
Semiconductor Complement: 20 transistors; 10 diodes.
Size: 13-1/2" wide by 12" deep by 4-1/4" high.
Shipping Weight: 18 lbs.
Maximum Power Consumption: 35 watts quiescent; 250 watts maximum; 50/60 Hz, 100, 120, 220, or 240 VAC.
Specifications:
Frequency Response:
Hum and Noise:
Impedances:
Tape Output:
Tone Controls:
± 12 dB @ 50 Hz;
± 12 dB @ 10 KHz.
