I have an MF X-Can v3 which came with a plug pack power supply, I thought I'd look into building a better option similar to the linear supply I built for a Bugle Phono pre amp I made.
I noticed that the X-Can only requires 12-0-12 Vac, does this mean all I need is a transformer in a nice box with the appropriate hardware, switch and fuse or am I missing something.
Maybe an RFI suppressor or something similar.
Cheers
steve
Cheers
steve
Most probably you're right, Steve. 😉I noticed that the X-Can only requires 12-0-12 Vac, does this mean all I need is a transformer
There's lots of suggestions on proper PSU designs both on this forum and on the entire web.
I'd suggest to look for kits in the forum shop and the vendor section and build a CRC or CLC
style PSU with a 2 x 9V 30 to 50 VA toroidal.
Ok, I see you mentioned, it's 2x12 V AC. Then you'd just need the transformer only.I don't need DC, that is done inside the X-Can.
However, I'd strongly recommend to build a DC PSU, giving the chance to provide
improved filtering (CRC or CLC with increased capacitances), then feed the X-Can
with clean DC only. When done right, this will definitely reduce noise.
You probably already know that stuff:
Modding the X-can v3
AB TESTS
Musical Fidelity X-Can V3 tweaks
X-Can V3 Capacitor mod
Data til musikk Påvirkning av kvalitet på pc/mac i forhold til lydkvalitet gjennom ekstern dac - Side 3
Big Sky Audio, LLP - When You Are Serious About Sound™ Stereo Amplifier Restoration & Upgrade Service
