Hallo,
I am working on my second DIY-project and exactly on 'tortello' (Marcello) project:
http://www.diyaudio.com/forums/showthread.php?postid=19396
http://www.headwize.com/projects/showfile.php?file=pellerano_prj.htm
I used the second version of 'digi01' (Zang) boards:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=29784&perpage=10&pagenumber=1
The first time the amp worked perfect; bias set at 175 mA. After a couple of hours the bias of one channel dropped to 30 mA. The second day I monitored both channels and the bias of the broken channel started perfectly and slowly dropped to the minimum.
I checked the transistor and both the mosfets and they seem to work, also the trimmer that set the bias works ok.
In the weekend I hope to have time to fix the problem, can somebody have idea on what I have to looking for?
Thanks in advance for the answers and thanks to Marcello and Mr. Nelson to give me the possibility to have a fun with this project.
Ciao
Peppe
Ciao
Peppe
bogdan_borko said:Q3 sholdn`t be near Q1 heatsink!
Yes Bogdan, Q3 is far from the heatsink.
Q1 and Q2, instead, are thermally coupled and electrically isolated.
Update:
I sostituited both Q3: no changing!
I inverted Q1 and Q2 from one to the other channel and now both channels have the same problem: when the temp rise the bias current goes down!
Never saw the temp raise more than 40° C.
What's strange is I made two amps: the first one works incredible well! The only difference is the imput caps, on the second one are electrolit instead non polar MKT.
Nobady have an idea to help a newebe? 🙂
Hi Peppe,
check the DC voltage values as pubblished in the Headwize page: you should find similar values.
As soon as the amp goes warm and bad, re-check them all and probably you will find the problem.
Even a passive component (R2 for example...) can drift from the nominal value, and so to change the bias point of the circuit.
These problems are quite easy to discover.
Feel free to contact me, the email address is in the HW page.
Good luck!
Marcello
Good luck!
Marcello
Hi Marcello,
understud! I have time only in the week-end and hope to find the problem.
In a way to have trouble is not too bad ... probably a good way to learn more.
Thank you very much, Marcello.
Peppe
Peppe
luvdunhill said:
Looks nice! What parts did you decide to use? Are those red capacitors Black Gates?!
Thanks 🙂
No, they are Elna Cerafine for audio like the smaller ones.
The psu caps are panasonic.
Ciao
Peppe
Wise words!
This is the diyAudio spirit! 😉
No jokes, if you are in trouble, please send me an email...
All the best from Chiavari
Marcello
tortello:
would it be possible to use a 2x22VAC 120VA toroid with this amp? I know it seems overkill, but I happen to have on in my hands right now 😎 Adding more heatsinking wouldn't be a problem...
here's the schematic:
http://taihu.bjtzh.gov.cn/~digi01/minizensch.GIF
thank you!
thank you!
Yes,
it will work correctly, but you should re-calculate the polarization network to optimize performances.
Unfortunately I can't do without YOUR transformer...
Or you might decide to sacrifice the excess of voltage increasing the PI filter resistor (R18): you will tame down the noise, in this way, and will be able to set the correct bias point for the circuit.
Best regards
Marcello
Best regards
Marcello
hm, I'm not sure how to go about the recalculation. There really isn't much other than the output specs 2 X 22VAC @ 2.73A and the regulation, which is 11%. What would I need to measure? Also, it seems that I would have to increase R18, but I will calculate it and see what I come up with. Perhaps this is easiest.
Thanks!
Thanks!
Let's build the circuit(s) and set R18 to have the same drain voltage for Q1 as the "original" one.
R18 will be higher in value.
Of course the time costants of the power supply will be different...
It would be better to re-bias the whole circuit, but this is a less easy way.
Marcello
Marcello
- Headphone Systems
- Zen-like headphone amp trouble
