I’ve been reading info about TDK 2CP-2511/4CP-2511, there they states “Please take care not to use for setting resistance value, as, if so, we are afraid that a trouble may happen.” Therefore the question. Otherwise no problem, got it!
If you want the ones that are going to give you a closer match with less left overs (waist), you need to hunt down the NSL32SR2S (the 'S" on the end stands for selected) you still have to mach them up, they cost more but you 'll need far less of them to get the matched sets, and you'll get a lower minimum volume from the "S" ones as they have a lower min impedance.How do i make sure, that the ones i get, are all grade A ?
https://www.digikey.com/en/products/detail/advanced-photonix/NSL-32SR2S/5039807
https://www.crestcomponents.com.au/nsl32sr2s-p-165.html
https://www.heisener.com/ProductDetail/NSL-32SR2S
Cheers George
- Analog Line Level
- Lightspeed Attenuator a new passive preamp
