You can import the text into excel from the data page, get data from text CSV. Delete the coherence column export and see if it works
It works but I was wondering if there is a better way?
Look in the Smart settings to see if there is a way to export text without coherence, or use REW to export the impulse response instead. I suppose it depends on how many times you will need to perorm the task as to how annoying any method will be.It works but I was wondering if there is a better way?
