If they use decent parts, this board seems to be a reasonable low cost option for line or headphone amplifier PSU. It uses a floating LM317 per side to get up to 35 volts out. Any first hand experience with this?
Class A Parallel Regulated Power Supply Finished Board | eBay
I used to use LT1083 based dual channel PSU. But they are getting expensive and harder to find.
Thank you for your comment. Any onboard component upgrade worth considering?I have used this supply on a few designs so far. It is a decent supply for the money! I ran one on a Rotel phono where the power supply blew and it was dead quiet.
I am looking for a "best value for the money" PSU kit for an opamp based MC phono stage. I do not need super low noise PSU since the opamp have good CMRR.I left it as-is.
I looked at the AMB Lab Sigma22 PSU. It seems too expensive an overkill for my purpose.
I have used the AC-DC LM317 LM337 LF353 Servo PSU for line stage preamp. It works very well too. I may want something "slightly better" for the phono stage.
Hi, If you want a power supply for a MC phono stage then any LM317 or associated P/S will come up short.
I used to use 4 SLA batteries, but last year took a chance on one of these after good write up from various members. 5-28V STUDER900 Regulator Power Supply Board Can Assembled Into Double Powe M7J9 | eBay
I can report that it is very quite, even quieter than SLA batteries, Only way to go for phono circuits.
Cheers
@thuanth43
That Studer900 psu is excellent. I used many of them to power to power my headphone amps with great satisfaction.
Their listing is confusing....is it a board only or a full kit board and components...?
Studer 900 PSU
low noise Pre-Amp / DAC power supply MJE15034 TL072 Regulator based on STUDER 900
I assume that you are referring to the e-bay kit, not a genuine Studer 900. The price is right, about the same as a dual channel LT1083 PSU board. I will order one of this Studer 900 clone to check it out.
Thank you for the tip. I found this link with the schematic.Hi, If you want a power supply for a MC phono stage then any LM317 or associated P/S will come up short.
Cheers
@thuanth43
It's a kit with components. You need to assemble it yourself.
Thank you for your reply !
That is what I had hoped
I have ordered one...
Assembly is not a problem...
Enjoyable festivities to you and yours !!
The kit that needs assembly is going for under $20 on e-bay. There are also several offer of fully assembled PSU for $7-10 more.Thank you for your reply !
I ordered the kit which should arrive early next January.
- Power Supplies
- Need +/- 24 volts PSU
