No more peak, no more overshoot
the j113 is the best compromise between distortion and stability
Thank you for satisfying my curiosity. I would call the step response characteristic something like on the verge of oscillation. Critically damped if you will.
During the rise, before the damped ring-down on the flat top, there are two distinct different slopes. I am curious why the rise has two different slopes.
Bonjour,
Last try with with J113, dual compensation proposed by Elvee. (Thank you)
square wave with 10uF and 1uF
89° phase margin with 1uF
spice file : Simple CFA Circlotron J113 version | Circlotron Audio
I will do the same with the 2SK170
Nice damped ringing insured by output inclusive compensation.
Try to be completely GND independent (high Z to GND), meaning true balanced input (XLR: pin2, pin 3 only), so connect mid 100 k input node (now GND) to mid 100 R (2 x 50 R) feedback node and sim if it is problem free.
HI,
Thank you for your interest, I tried to remove the GND
I have trouble choosing a reasonable current, 20X feedback and have a sinus output
With 50ohm on RA I have a good sinus but 8mA on Jfet
In your opinion the BC560 are enough to dissipate 200mW idle and 285mw Max?
The KSA1381 are no longer available
HI banat,
yes I will try this compensation solution. thanks
Do you remember ?
https://www.diyaudio.com/forums/att...1410021153-vssa-circlotron-drive-modified-jpg
Do you remember ?
For shure that it is possible to acomodate that VAS on your VSSA Circlotron project , it is look nice with that CCS on VAS collector side , any way try to simulate this schematic to .
A small test during the lunch break
It works, but it would take a VDS> 40V
(do not watch compensation)
I tried, it does not work, Do you want asc?
for the moment the only one that gives a good result is the one that Elvee had proposed, but it must be adapted
Alternative closer to ground connection of neutralization elements C6/R24 and C7/R25
- VSSA Circlotron
