We are using SDA NDK on Kali that have better phase noise then Crystek so I see no advantage on changing it.
Thanks Ioan, I'll leave 'm in then, no need to change 'm out.
Is there any way to buy a 22/24Mhz Kali somewhere ? I bought one a long time ago and i need a second one, but it seems that nobody has them available anymore. Or does one of you know where to look for it ?
Audiophonics have them in stock:
ALLO KALI Reclocker I2S FIFO Sparky SBC and Raspberry Pi 22/24MHz 192kHZ - Audiophonics
Cool thanks, i looked 3 days ago and they didnt have them in stock... Ordered one.
Does anyone know of any other options for SPDIF output that would work with the Kali?
Is there any compatible board or projects to get spdif from KALI i2s?
I need anything that able to produce good SPDIF after KALI.
Please help )
Hi, I’m considering to buy the Kali to feed an i2s signal to a tda1543-based diy dac. Will this only be possible with the 22/24mhz version or can I also go with the 44/48mhz one? Can someone explain why? I’d like the kali to also be future-proof, in case I decide to also use it with other higher resolution DAC chips later. Also the 22/24mhz one is currently not in stock.
Thanks,
Denis
Thanks,
Denis
@denkol: Just FYI in case it could be interesting:
https://www.thewellaudio.com/twsafb-lt/
If you download the windows settings software you can see a list of DACs which can automatically be selected to work with this FIFO including TDA1543 DACs.
I otherwise do not now if this "will fit your bill" but thought I would mention it.
Cheers, Jesper
Cheers, Jesper
- Vendor's Bazaar
- New FIFO buffer for RPI/SBCs
