Speaker Turn On Delay and DC Protector Board Set (V3)
here is the datasheet from upc1237... it does have latching.
pin 3 does the job of latching.
Prasi:
A follow-up question: what part did you specify for B2?
Regards.
Any of the following will work fine. 5.08mm x 7.62mm pitch.
https://www.mouser.in/c/semiconductors/discrete-semiconductors/diodes-rectifiers/bridge-rectifiers/?if - forward current=1 A&mounting style=Through Hole&package / case=DFM~~DIP-4&instock=y&sort=pricing&rp=semiconductors/discrete-semiconductors/diodes-rectifiers/bridge-rectifiers|~Package / Case
Also attaching slightly modified files, where in I have removed the solder mask for speaker traces and also added a pinheader for ground reference.
  • BTM COPPER-DIYA SSR PROTECT.pdf
  • speaker protect and startup delay - mod-SSR-TRIAL1_2023-12-25.zip
  • TOP SILK-DIYA SSR PROTECT.pdf
Reactions: 1 user
ResisterClone
Joined 2011
Any changes to this design? Has it been proven to work?
thanks very much
Whats the time on the turn on delay and how would I increase to say 15 secs?
