I know the difference, but i also know that you can use lower feedback resistor values for lower outputs so that +-5v supply won't be a problem.I bought both ADA chips so i will see the difference soon.ADA4899 is advertised as a better chip especially because of the pinout and slew rate , but i don't know ...
