Make one from 3mm aluminium plate and some countersunk 3mm bolts, like I did. If interested, I will post some pics
I'd be interested to see. I've got some 3mm plate spare at home...
We did one as a group buy which I designed. I have zero feedback from the participants and cannot comment if it did work as intended on their routers (most were Bosch POF1400 ones). I can confirm it works great on the DeWalt DW625 router and is accurate down to the 1/10 of a mm.
If you think you can adapt it, I will gladly send you the design files - they`re CAD files for routing so you just need to find a CNC company to machine one from 4mm aluminium or steel.
Here`s the thread:
EU: Router circle jig 56mm-420mm in 1mm step
Here`s the thread:
Will upload them over here later today. Perhaps we could improve it a bit
Oh I would love that!
Do you know if they work with Triton routers?
I might be able to produce a very small amount at my university.
I've used one for over a decade and still love it... I am concerned that one day the paint will wear off but it has already paid for itself a long time ago.Look up jasper jig
I have a Jasper jig and find it very cumbersome to use, but also have this one, it is continuously adjustable and much easier to use than the Jasper jig:
https://www.homedepot.com/p/Milescr...n21gseJZAJ9tpU9Qx_RoC4IoQAvD_BwE&gclsrc=aw.dshttps://www.northerntool.com/shop/t..._Hg7-MvBs-NJqSk7CHsfC2yui0lnQsRhoCm6oQAvD_BwE
Lukas
Lukas
2 minor caveats with that Milescraft circle cutting jig:
1 -The pivot pin that came with mine had a smaller diameter than the pivot hole, so it can wobble a little. No biggie, I found an old drill bit that fit exactly into the pivot hole and used that for a pivot pin.
2: The scale is not super accurate, probably OK for carpenter level work, but for precise diameter setting use a tape measure or metal ruler to set it exactly.
I still MUCH prefer it over the Jasper jig.
Lukas
Lukas
awesome thanks guys. I'll check out that one at home depot
I recall I got the idea from a posting at parts-express.com.
Here's a link:
DIY Circle Jig -
Techtalk Speaker Building, Audio, Video Discussion Forum
- Design & Build
- Equipment & Tools
- circle cutting jig for router??
