Monster MPA3250
It is like a mono block type setup with 2, 3 or 5 channel depending on model mpa2250, mpa3250 or mpa5150. It is a very nice amplifier and sounds excellent. The design is exceptional producing fine details and quick bass. I would say what go in comes out. Nothing is bled out in transmission like some amps. I have used multiple amps in my HT and nothing in price range that you can purchase it for now gets very close. It is great with music also. It doesnt choke out like some amps ive tried also. The closest sounding amp I would say is Anthem MCA's. I wish I could explain more but that is about my limit. Maybe someone else may explain more detailed. Hope it helps.
I have a 3250 that isn't working that I haven't been able to fix yet. It goes straight into protection mode and I can't find reason. It does have one missing module. That block is now isolated but still no luck.
I have another 3250 still works perfect and a 2250 for rear also. I wouldn't swap for anything in its size class.
