Noble Potentiometer Identification
Can anyone identify the Noble (Taiwan) potentiometer shown? I find nothing on the web and messages to Noble have gone unanswered. A datasheet would be helpful if someone has an old catalog from late 90s to early 2000s. I am looking at Bourns now to see if something that's close will fit.
Moderator
Joined 2011
You should be able to find that form factor pot easily at most distributors.
Seems that it has a metric shaft, which is common now.
Any other requirements, is there plenty of space around the pot on the pcb?
It looks like a Bourns 51 series will work. Mouser carries the 5K linear taper but not the 10K audio taper. Digi-Key and Newark do not have the 10K audio either and it may be difficult to source that one.
Thank you for jumping in and helping!
Moderator
Joined 2011
You may want to check whether the pot is linear or log first.
Set it to exactly half rotation, then measure from the wiper to one end.
If the measured value is close to half of the total pot value, it's linear.
Also I would check the front-to-back distance from the pins to the mounting surface,
at the base of the bushing. Some pots may vary in this dimension.
Gold mine electronics is in NV on.line none but maybe m qore in store..
Problem is many surplus stores have closed or greatly downsized dumping old stock.
Hopefully that diyer will have something
Another idea check check with local shops that service commercial hand held radios such as the ones police would use..the older ones used small pots like those.
I have some Motorola pots but they are alps.
Ideally go to local repair shops show them what u have see if they have anything that would work
