SSLV1.1 builds & fairy tales
diyAudio Chief Moderator
Joined 2002
I have a suspicion this one at least maybe has a difficulty so compare with resistor plate load also for bias behavior
Joined 2002
Salas there is some self power consumption of reg. to work OK, I measure circa 650mA @ R1 ande the load is 600mA?
Can typically regulate even on such a small spare mA margin, eats only few mA for itself. More spare mA is simply burning it for better output impedance spec.
Reactions: 1 user
Joined 2009
Thanks now I am confident with the reg. for heaters.
Could I ask what do you think of bias point choosen or let me know what do you like more?
TIA
Joined 2009
It seems the BiB powering heaters is oscillating. Attached pics measuring AC & DC.
  • VID_20230414_114708.mp4
    12.8 MB
  • VID_20230414_115330.mp4
    11.4 MB
Joined 2009
Vids with the dummy load, no oscillating. It's strange the cable is twisted and fixed to the chassis.
  • VID_20230414_120038.mp4
    3.8 MB
  • VID_20230414_120106.mp4
    6.1 MB
Joined 2009
Isn't the wire.
Joined 2009
Near 800mA still oscillates, could be the issue Zobel network related, because several times the tester reads 1 or 3 volts: I said because the zobel used is 4.7uF in place of 10uF?
Joined 2009
See what happens when start power 1st pic left side measuring DC, 2nd pic measuring AC: 50Hz near 3V, 3rd pic once stabilized measuring DC, 4th pic measuring AC once stabilized.
Joined 2002
Last one says 0Hz after stable so not hum but 66.7mV noise even if white noise its no good.
Top
