VRDN: bipolar regulator PCB for line level ckts: ±11V to ±20V @ 1.5A with "De-Noiser"
So I've built up one of these, and have another two to go. I really like this project. The final product is a dense (like me!) board with lots of adjustability.
The board markings are a treat. Positive/negative legs marked for nearly everything. Even some + markings on the back side. Excellent. I like the vertical resistors. What a treat. No more measuring for spacing. Also the orientation of resistors (marked with a circle) diodes (marked with a circle and the anode identified) . Much appreciation here. I've held my breath soldering a few items that connect to one of those large ground planes and just hope for the best when the solder doesn't flow to the other side of the board, but otherwise have had little trouble with the work.
I took the time to set up my shopping cart on Mouser with the associated part ID from the original spreadsheet. This helps speed me along the build because the parts are already identified on the boards. Maybe everyone else does this, but I just realized how handy it is.
Thanks, Mark, for a great project to work on! Can't wait to fire it up! (y)
Reactions: 1 user
Joined 2011
I mark the positive terminals of electrolytic capacitors with a "+" sign on the bottom silkscreen layer, just to give builders a way to double-check the polarity AFTER the board has been stuffed and soldered.
If the components are densely packed on the PCB, markings on the top side can become difficult or impossible to read. But you can still read the polarity band on the cap itself, then flip the board upside down and verify that it matches the polarity marked on the bottom side. Granted, this can be a little clumsy-- but it's a whole lot better than no possibility of double-checking at all. You get a little extra reassurance that you didn't stuff the capacitor backwards, and it doesn't impact board size or cost. Cost = zero, Benefit > zero, easy decision.
_
Reactions: 2 users
Joined 2019
It's a four layer board and two of those layers are ground planes. You're heating up a LOT of copper when you solder a VRDN board. Increase tip temperature, patiently wait for solder to melt and flow. It will probably require more heating time than you're accustomed to. Pause every twenty solder joints and inspect with high power magnifier.
Boy, it’s tough to get solder to flow correctly into a ground plain pad. The non-plane ones can be easily soldered at 620F/325C. I’ve been up to 700F/370C and even with flux the pad doesn’t get covered easily, especially on the large electrolytics!
I have a Metcal PS-900. For most work I swear by it: it works great. But with it's "smart heat" temperature control (meaning I let the system choose the tip temperature) I never actually know how hot it is. Metcal talks of "power output" and "Frequency" but not actual tip temperature! For a VRDN board, this does cause some worry while I build. As mentioned, I'm trying to believe that the heat while soldering is going to the ground plane (it probably is) but with parts like transistors I still wonder!
Joined 2011
If the solder doesn't melt then you can be pretty sure the temperature of the joint-being-soldered is below the solder melting temperature.
I set my Hakko to 405 degrees C and solder VRDN boards using a 3mm (1/8 inch) chisel tip plus eutectic 63-37 solder from Multicore. Works just fine for me.
Reactions: 1 user
I did a silly thing and attached D3 with the wrong polarity. (As a result, I could not adjust the voltage on the positive side.) Worse, in my effort to extract the diode without unsoldering a bunch of other stuff, I seem to have destroyed the pads. So I am looking for a way to solder a diode into an appropriate place.
Looking at the schematic and testing a blank board, it appears I could solder it between the square pads of R7 and R11, with the cathode (banded end) going to R11 and the anode on R7. And, lucky me, those are already the ends I have sticking up, with exposed wire.
Before I do this, can someone confirm that this is correct?
Joined 2011
I recommend you carefully and intensively study post #134 of the Scourge, Bulwark discussion thread (here is a link). Flying wirelead recommendations from the designer, are present on BOTH the schematics AND the PCB silkscreen. Your job as a builder is to follow the recommendations on the PCB. If you do, then the flywire indicators on the schematic will be trustworthy and accurate. If you ignore them --- well, as the minister says to Sheriff Bart in the final minutes of Blazing Saddles --- Son, yer on yer own.
I recently installed D3 and D4 into the D5 and D6 locations. Yeah, oops... I was lucky enough to be able to remove the parts and excess solder (and not the pads) but it cost me a bundle in that I ended up purchasing a desolder station to do the work. Hmm. Yes, the 4-layer 3 ground plane boards can be challenging!
Your new solder location looks correct - so says the schematic. Just double check the orientation before soldering it down. (I know you will this time!)
BTW: Geez, Mark. That flying wireloop reference is something I never knew before. Cool!
