FYI - Devore SEAS A26 kit alternatives
I was looking at the Devore Speaker $$$$$ & the Seas A26 kit, looking at the cost there's got to be alternatives.
$20,975.84 CAD (WHAT !!!)
https://vinylsound.ca/products/devore-fidelity-orangutan-o-96-speakers
$14,000 AUD
https://www.mcleans.info/products/devore-fidelity-orangutan-o-93
DEvore 0/93 Dimensions: 35.5″h x 15″w x 10″d 2.26 cuft or 64 litres
Google Translate
https://translate.google.ca/
YMMV-
GRS-10SFPC-8 Cheap
https://www.parts-express.com/GRS-1...me-Paper-Cone-Woofer-Black-290-912?quantity=1
Compare these two- around 800-1500 hz (up and down-about 10 db)
Seas A26
https://www.madisoundspeakerstore.c...6-10-2-way-kit-pair-based-on-the-classic-a25/
Sound Town STLF-10GA PA/DJ/Bass Guitar (gasp)
(?) 50 oz magnet, vented @71 litres hwd 36x16x10.25 (.75")= 2.53 cuft or 71.6 litres
https://www.soundtown.com/collections/raw-speakers/products/stlf-10ga
Faital 10fe200 4 or 8 ohm HOME HI-FI, PA SPEAKER SYSTEMS & BASS GUITAR CABINETS
https://usspeaker.com/faital pro 10fe200-1.htm
Audiopur RT7040 Planar tweeter
https://theaudiocrafts.com/soundtouch-ribbon-tweeter-rbnt1-pair
Russia post #19 crossover 4500 hz
https://forum.vegalab.ru/showthread.php?t=79335
Don HighEnd
https://www.donhighend.de/?page_id=8442
Visaton W250S
https://www.visaton.de/sites/default/files/dd_product/W 250 S_9034_9035_0.pdf
a cheaper Visaton W250
https://www.mouser.ca/datasheet/2/700/W_250-2322621.pdf
Vietnam- Visaton W250S-8 (Operating Fullrange) + Fountek NeoCD3.5H Two Way Speaker
https://linhkienloadai-vn.translate...uto&_x_tr_tl=en&_x_tr_hl=en-US&_x_tr_pto=wapp
old Vifa P25W 70 litres
http://www.sea.vg/vifa/P25WO-00-08.pdf
Vifa SA-130 speaker. 2nd page freq resp graph looks better. (Why couldn't they just use this freq resp. graph)
https://www.stereonet.com/forums/topic/93512-vifa-sa-130-plans-specs/
Any more?
Moderators- move this if necessary. TIA
If you search there are at least two threads on here that describe variations on the Dynaco A25/Seas A26 speaker including larger vented boxes and alternative tweeters and woofer (Morel CAT378 and Eminence BP102 spring to mind).
However, these speakers have been designed around some fairly unique properties of the drivers. They key ones being that the woofer has a very smooth fall off at high frequencies (it effectively has a 1st order low pass filter built into the design I.e. high inductance) and the tweeter similarly has a smooth rise at lower frequencies. The result is that you can use a first order electrical crossover on both.
Here is one of the threads https://www.diyaudio.com/community/threads/10-two-way-seas-a26-alternatives.310176/
Reactions: 1 user
frugal-phile™
Joined 2001
Reactions: 2 users
Devore Orangutan 0/96 (short speaker with stands)
$20,975.84 CAD
Frequency Response: 26Hz-31kHz
Sensitivity: 96 dB/W/M
Impedance: 10 ohms
Dimensions: 35.5″h x 18″w x 12″d including stands
The cabinet measures 28.25" high x18" w x 12" d (.75 mfd-2.68 cuft or 76 litres)
Devore Orangutan 0/93 (tall speaker- no stands)
$11,635.65 CAD
Frequency Response: 30Hz-31kHz
Sensitivity: 93 dB/W/M
Impedance: 10 ohms
Dimensions: 35.5″hx15wx10d (.75" material= 2.26 cu ft or 64 litres)
Weight: 21 kg or 46 pounds
run fullrange, no crossover
Faital 10fe200
Note fig 1 with no crossover-black line
https://ampslab-spk.com/2021/05/18/10fe200-review
from Mike Chua,
"Listening Impressions​
I am listening to the 10FE200-4 without any crossover and I must admit she sounds wonderful. There’s no brittleness or harshness in the treble. I’m so impressed that I would even recommend using the 10FE200 for public announcement or speech reinforcement. There’s no need for any horn because the 10FE200 extends to 4kHz. This bandwidth covers the human voice."
From PartsExpress Q&A
https://www.parts-express.com/FaitalPRO-10FE200-10-Professional-Woofer-8-Ohm-294-1201?quantity=1
I want to use this as a pa vented box woofer can you suggest box size port diameter and port length?
Rajinder S.Feb 24, 2017
Best Answer: I would recommend using this in a 2.5 cubic foot box that is tuned to 50 Hz. Two 3 inch ports that are 2-1/2 inches long would do well here.
(2.5 cuft= Tall hwd "36x16x10) (Short hwd 28"x18x11.5)
or
I want to use this driver in the smallest enclosure possible (ported), reaching ~ 45hz, does anyone have any suggestions?
David MAug 13, 2017
Best Answer: We would suggest this driver as a mid range or mid bass driver used with another woofer below it for the low end. When I model it I get 3 cubic feet for 45 Hz using a 5" port that is 1.5" long, but the driver is limited to about 65 watts RMS before it bottoms out. However, it would work well as a mid with another woofer below it to take up the slack for the low end and allow this driver to play mid bass and midrange frequencies which it would be better suited to produce.
Greg TSTAFFFeb 7, 2019 (3 cuft= hwd 36x16x12")
Visaton W250S
Volume/Principle
70 litres / Bassreflex; bass reflex 2 x BR 15.34 39 hz
HWD 36"x16X10 = 2.46 cuft @70 litres
Vietnam-Maybelle Audio. Visaton W250S-8 (Operating Fullrange-just a zobel) + Fountek NeoCD3.5H Two Way Speaker
tweeter crossover 3 ufd, .3 mH, 4.7 ufd
woofer zobel 22 ufd , 12 ohm resistor
plus
Audiopur RT7040 Planar tweeter 93 db (cheaper than the Fountek Neo)
Russia post #19 crossover 4500 hz -similar to the Vietnam-Maybelle Audio crossover
better than nothing youtube video-
I heard De'Vore silverbacks and they are easily as good as anything selling for that price or at double of it. Jeff , the owner said he had those Orangutans in the room and they were like Ole Spendors for Grandpas comparably - woolly and unrefined. Incidentally, I
've only seen them being owned and raved on by 75+ young audiophools sporting hearing aids.... This besides the DIY folk, who sensed blood on the scale of 47 labs cloning spree and "Savings". Have you no pity on those trees you will sacrifice buying all this plywood because you think you're saving big ?
Who said anything about plywood. These aren't clones- no Seas woofer, no Seas Tweeter or no Morel Tweeter. Devore uses mdf box with plywood baffle (he must have some pity on those trees).
Just similar boxes-Alternatives, woofer fullrange. Clones would be exact-including drivers.
Anyone with bookshelf speakers @ the size of Rogers LS3/5A- are you calling them clones?
limono please post your concerns here (people even used plywood to build the boxes (Gasp)-
Devore Clone
https://www.diyaudio.com/community/threads/devore-orangutan-clone.272810/
I'm calling a spade a spade. There is Devore Orangutan cloning spree going on on DIY audio comparable to Proac cloning spree some years ago and 47 Labs cloning spree where supposedly big bucks can be saved and your post is pointing an even cheaper alternatives to get something close to actually nobody or only a very few know WHAT. It is entirely greed motivated activity since three legged dog wouldn't sniff that "design" for free if not for John DeVore pricing it to stratosphere probably knowing that morons on DIY audio will grab it like a Holly Gospel and will sing the prizes of timeless beauty of that genius design.
How can anyone be such an idiot is beyond my comprehension
So I can't use the dimensions (similar-not exact) of a Devore Orangutan 0/93?
How about a 50 Litre box still different drivers-Alternative (not a clone-a facsimile)
I wonder if the Devore Orangutan 0/93 is a cl--- of the old Boston Acoustics A100 (timeless)? Spade a spade?
Is this the basis of any builds?
https://www.seas.no/index.php?optio...ticle&id=475:seas-a26-kit&catid=66&Itemid=345
"The A26 loudspeaker design is based closely on that of the legendary Dynaco A25 loudspeaker"
shame a clone.
Devore Orangutan
https://positive-feedback.com/Issue75/devore_orangutan.htm
"PF: What speaker most influenced the design of the O/93? I've read reviews citing its similarity to certain Audio Note or Snell boxes (I own the Snell J/II series).
John DeVore: There aren't many 10" 2-way speakers out there, an old Boston Acoustics model here, a Dynaco there, though both of those are well over 30 years old. Original Snells were an influence too, but all these were fairly inexpensive, compromised designs. They did do one thing though; the Bostons in particular, suggested to me what potential there might be in a 10" 2-way speaker with a 1" dome tweeter. I sold the Bostons when I started in retail, and it was clear to me that the 10" 2-way was far better than the more expensive model in the line that added a midrange driver. More influential though were the larger designs from Altec and the like. Explosive dynamics, rich tonal colors, high sensitivity and high impedance. The goal of the Orangutan series was to provide a large measure of those qualities, without the drawbacks, in a domestically acceptable (even desirable) package."
Nobody but Devore knows what the Devore crossover is. If someone copies the crossover then it could be a true clone. But there's so many alternatives.
If someone builds a box with different dimensions than a Devore product then it's not a clone.
Different drivers- not a clone,etc
Different boxes, drivers, crossovers = different sound.
What's a clone?
This thread says, "Alternative"
If the Moderator(s) want to change the title or anything in this post to,
"10" woofer and tweeter combos for 2.5 cu ft or 70 litre boxes" go ahead.
The TNT Hotch Loudspeaker
(" Le is a metric that says something about woofer speed. ")
https://www.tnt-audio.com/clinica/hotch_e.html
Woofer Speed
https://diy-audio.narod.ru/litr/WooferSpeed.pdf
Seas A26RE4 - used in the Seas A26 kit
Voice Coil Inductance (Le) 3.37 mH
https://solen.ca//storage/media/WdFzwUa8MgF9pdHcNnTHsx4RjlKvbTeIJ42dpMgn.pdf
Faital 10FE200-8
Voice coil Inductance (Le) 0.42 mH
Visaton W250S-8
Voice coil Inductance (Le) 1.5 mH
per Devore- here's some of his influences.​
Dynaco A-40 XL
Snell Acoustics E-II
Snell Type A the original,"In 1976 Peter introduced the highly refined Type A loudspeaker that launched Snell Acoustics. The company began in a small space in Newburyport, Ma."
Naim Audio ...
Wide Baffle
https://www.diyaudio.com/community/threads/the-genus-behind-wide-baffles.300733/
http://www.troelsgravesen.dk/download/IBL.pdf
more alternatives: YMMV
2 pi speaker-cabinet to your liking. Built with a Nice plywood baffle and black sides.
https://pispeakers.com/Prices.html
https://pispeakers.com/Measurements/twoPi_tower.html
AudioCircle Hestia OB (GASP MCM)
https://www.audiocircle.com/index.php?topic=108003.0
page 2 post#36 Plate amps for the Dayton PA255
(Skip the Dayton PA255 woofer to keep the single 10” woofer . Place the drivers for a more traditional Boston A100 or Snell Acoustics E-II look.
Build as :
(1) Baffle with 2"x2" frame covered with fabric for WAF- with a subwoofer
(2) Front, sides plus Open Back- with a Subwoofer
(3) 70-75 litre Ported Box
Vifa- Peerless D19TD 87.5 db
MCM 55-2981 10” 93 db
https://cdn.shopify.com/s/files/1/0809/2387/files/D19TD05-08.pdf?1883630718988819778
https://canada.newark.com/multicomp...-250w-rms/dp/13T7693?pf_custSiteRedirect=true
"The inductors are Jantzen 18 AWG air core and the Caps are Dayton Audio Polypropylene. I use the Dayton pre etched 2-way PC board number 260-130 which makes a nice finished product. I typically mount them on the baffle back with rubber washers."
L1 = 1.80 mh 18 AWG
C1 = 7.5 uf
L2 = 1.40 mh 18 AWG
C2 = 5.6 uf
https://web.archive.org/web/20211024064727/http://mh-audio.nl/Calculators/BRH.html
MCM 55-2981
"Re: Hestia OB, an ambitious low cost, 3-way OB design
« Reply #327 on:[/B] 2 Feb 2024, 02:56 pm »
I built mine without the woofer with the same baffle width and mid and tweet location and used the Golden Ratio for the height. Using them near field with a Nelson Pass ACA amp kit and they sound wonderful. I too wonder if using more esoteric drivers would increase the pleasure ( or just drain the wallet)? After some thought, I do not think more expensive drivers would be a wise investment with this design. it is very darn good just the way it is. Using an 8" Yamaha NS-SW050 subwoofer and it works very well."
If anyone builds any of these options please let us know.
With some smart choices the speaker pair should come under $20,975.84 CAD and the 'drain on the wallet' won't be too bad.
If you want to build a Devore clone:
Devore Clone discussion
