Spruce wood for cabinet??
frugal-phile™
Joined 2001
Cal, the speakers in post #27 https://www.diyaudio.com/community/threads/spruce-wood-for-cabinet.411890/post-7665204 has ¼” “veneer”, the outer ply (aka “veneer”) in the bamboo is 3mm (and sold seperately .as veneer). Imagine 5 of those stacked in plywood fashion and glued together in a vacuum bad… i imagine really super plywood. And there isno reason hempstrands couldn’t be used similarily to create even stronger (and cheaper — hemp grows almost anywhere so it could be made locally) plywood. .
dave
frugal-phile™
Joined 2001
The pics you show are not strand bamboo, they are vertical bamboo with a tiger strand veneer.
Neopolitan Strabnded Bamboo plywood from Plyboo.
https://www.plyboo.com/products/plywood-veneer/plyboostrand-bamboo-plywood-and-veneer/
dave
Whether this bamboo wood good for speaker cabinet? Thanks!
Composite Bamboo ply is great stuff to build cabinets with. It ain’t exactly inexpensive though. I have a cutting board that has lived outside since 2007……still looks good and lies flat…..I can think of no better test than that. In all fairness, it’s on a Teak table……and the table looks a little better.
Reactions: 1 user
Therefore, which one is more adequate for speaker cabinet between the two attached pictures?
Reactions: 1 user
Yes pics 1 and 4 are vertical and the second best. Pics 2 and 3 look to be horizontal and are considered the least desirable for this. Although it may be just fine, the other two are considered superior.
You meant the bamboo ply from the attached pictures are the best?
FWIW, I had to replace a section of countertop in my kitchen last year, so I took my wife to the local hardwood store to look at the bamboo countertop slabs they had in stock. They happily opened up a bunch of them, and every single one had checking and splitting that made them unusable. I'm not sold on the long term stability of those bamboo products. With the price of Baltic Birch going through the roof, I don't know what I'd use for a box anymore.
Bill
Stockton, CA
Reactions: 1 users
