Dual membrane planar magnetic (both active driven)
I suspect, the mass reduction by alu, CCA wires (related to copper) well masked by mass of necessary membrane coating (glue, for example). Did you ever measure the mass of glue on membrane? At the Magnepans seems dominating part the glue and the Milloxan. Furthermore this layer make better mechanical coupling between wire and undriven foil sections, gives a better high-frequency response (paradoxically). Perhaps the copper can be enough good (against its higher specific mass)?
Maybe your driven mass is too heavy for the magnets .Lack of control.
Have you tried to measure thiele small values .Too high Q value.
Underneeth here some measurements of my AMT´s . One with soft film PVDC Saran and one with mylar.
Might be different aluminium thickness too
Bernt Båndsei
Reactions: 1 users
When running double membranes you also have higher force factor pushing the air. So if you extend the baffle the bass response below 250Hz will increase.
So almost no adding cost you will get a huge bass boost with a wider and higher baffle.
I have tried it on ESL 63, important to NOT make a H frame rather a v shape where the baffle is pointing back wards.
Here’s an interesting dual sided diaphragm and most likely have a symmetrical magnet arrangement on both sides of the screen
Are you sure? At another side of magneted plate isn't useable induction, because the fluxlines close via steel plate. Perhaps the manufacturer takes one more magnet assembly to the plate. Or is this a prototype, and contains one membran behind the magnets (as at early Magnepans)?
Reactions: 1 user
Reactions: 1 user
copper is a no go for top end , and i use alu tape. so there is no extra glue over everything. just the traces with glue underneith
Bernt Båndsei
nope i did not :( but i am sure Q went up, well the whole thing was interesting but i think ill make a push pull as next panel. more expensive though but see how it plays when compared. it makes having lower res more easy and damping more easy and lower Q and more output, and l;ast but not least less coil making and stretching, downside.... price
Reactions: 1 user
