Pearl 3 Burning Amp 2023
I would say, that it was a not so lazy sunday...
PEARL 3 - single OPAmp in the cases.
Greets
Dirk
Reactions: 1 user
Verify that the TTA004 and TTC004 are in the proper positions on the bad board.
U3 and U4 are the halves of the dual opamp.
This would be very simple to check, swap the opamp left to right.
A004 and C004 are in the correct positions, and I've swapped the opamps between the boards to no effect. I've also re-checked all of the cabling and channel connections and it does indeed seem to be a problem with that board and not anything pre- or post- the Pearl 3.
Joined 2004
Troubleshooting can be frustrating. If you have not done so already, flip the board and carefully inspect for solder bridges. It happens...
Next, set your Voltmeter to DC, ground the black lead, then probe and compare bias voltages between your known-good and faulty boards to verify that they are the same. Check supply rails, output, and both sides of R1 as a start.
Reactions: 1 user
Had it at 100ohm, however perhaps I should have used a different setting. Hagtech site mentions that, with the SUT in place, the cartridge sees:
Phonostage: 47k, Turns Ratio: 13, Loading = 278.1 ohms.
Piccolo Zero
The Piccolo Zero is an active transimpedance gain stage meant to replace an SUT. Gain of such a transimpedance stage is given in Ohms (volts per amp), which is also the feedback resistor value. A good starting guess for gain can be made knowing the cartridge's internal resistance (plus resistance of tonearm wiring) and output voltage:
Resistance: 40 ohms,
Voltage: 0.15mV
Gain = 1333 ohms
Pearl 3 - Denon DL-S1 MC cartridge load 1000ohm seems to get close to the sound with SUT.
Reactions: 1 user
@bentconvert and all,
Dip # 8 and #6 did the job. #8 Took away nearly all of the whine, but there was still a very high-frequency whine (I mean very high). So I tried various combinations, and #6 took that away and did not affect the sound much...Of course, I read about number #8 for HOMC in the build docs, but did I remember ?noooo.....LOL! So many thanks to @bentconvert and @6L6 ..
The unit sounds significantly better than my older pre and I absolutely love the sound of the Hana! It's a whole new level of audio experience for me.
Reactions: 4 users
On the inoperative PCB, are both the LED lit?
They are, yes.
What is the voltage from opamp pin 4 to gnd? From pin 8 to gnd?
On the good board, pin 4 to gnd is -15V and pin 8 to gnd is +15V. On the bad board I'm reading -6.8V and -.061V respectively for those pins.
How tall are your standoffs? Perhaps something is shorting out underneath?
10mm tall and nothing from the board is touching the chassis underneath.
Either side of R1 on the good board reads 5.525v and 14.08v and I got a big zero on either side of R1 on the faulty board. I'm checking for solder bridges and easy-to-find shorts and there's nothing I can see. I'll keep looking though.
Sigh. Yep.
Only checked those like three times. Or thought I did. I will swap and if you don't hear back from me, my problem is solved. As always, thank you so much for the help and suggestions. I'm getting better at this with everything I build, but sometimes the easiest oversights amount to literal silence.
6L6
Moderator
Joined 2010
Don’t beat yourself up, that’s great news that it’s something so straightforward to fix! AND good news that it doesn’t hurt the regulators or the circuit when that happens.
Will be looking forward to hearing your impressions of the Pearl 3.
Reactions: 4 users
Ok. Swapped the regulators to their proper positions and we're good to go. Records are spinning and music is playing. So far, the preamp sounds great. It replaces a Hagerman Bugle 2, which sounded amazing, but the Pearl 3 is already leaps ahead.
There is however some mysterious noise in the background - a mix of hum and other stuff. It's subtle when the volume is set at a reasonable playback level, but super obvious when there's no signal but the volume is turned up. I recorded an mp3 of the noise, with my iphone, about 2 inches from my speaker. Click here for it. The noise is in both channels.
Cables have been swapped, and it's still there. I've got some ferrite clamps arriving in a day or so, which might help. That said, if you've ever heard this noise and know what it might be, let me know. I'm so close on this - I just need that background to be quiet.
FWIW - VPI Traveler TT, Goldring E3 cart, Wayne's BA2018 Pre, and Aleph J amp.
