Alpha Nirvana 39w 8ohm Class A Amp
Hi Andy
Can i ask you something ? once you make the version 4R same story here
Which is the bias Ampere that you set your amp?
Did you put also the capacitor C134 2200pf?
I see your construction in a box how about the temperatures ?
Kalimera, Nikos.
I used R15/R16 (as named in Hugh's 4R schematic - these are R141/R142 in the "as built 8R schematic") at 0.12R - which was designed to give 3a bias.
C134 (in the "as built 8R schematic") doesn't appear in Hugh's 4R schematic - but is obviously on the PCB. So I suspect I did put C134 in - and it would've been 2200pF, as per the "as built 8R schematic".
Yes, the 3a bias current - whilst it enables the 4R circuit to be stable into 2 ohms ... does create a lot of heat. :( I originally had each pair of output devices bolted to a CPU cooler - with a fan underneath it (and a hole in the base of the case). This kept the devices to about 60 deg ... but, even with the 12v fans being run at a lower voltage, I heard too much fan noise (not surprising, as there were 4 fans!).
So I re-housed the amps in a 5RU Modushop case, having 300 long & 210 high heatsinks; these don't cool the output devices quite as well as the fan configuration did - so I am about to change R15/R16 to 0.15R (which should reduce the heat output - and the device temperatures - slightly).
Reactions: 1 user
Κalispera my friend Andy.
Thank you very much for the construction details.
I have seen your construction.....however, due to the height of your box, you have placed the active fan not vertically but horizontally and the temperature is trapped in the radiator. These active fan work much better when they are vertical. I have tried as I mentioned above with classic heatsinks, but the heat dissipation is much worse. The problem is in the heat that is trapped above the body of the mosfet, and for that you also need cooling in the housing, see my photo.
In this way I have achieved 41 degrees Celsius at 3,188 A.
Am in the process of replacing the current 0.12R R141/142 with 0.15R.
One amp is done - so, seeing how 'topless' shots are in vogue atm, I thought I would post one:
The case is a 5RU Modushop 'Dissipante'. Transformers are Aus made, from Tortech, spkr terminals are EIZZ and input RCAs are Vampire PCB2FA (unfortunately, no longer available :( ).
Reactions: 2 users
Alas - I now need some smart suggestions from people who can help me figure out what is wrong! :(
After replacing R141/R142 in both channels, I reassembled the amp and switched it on - and nothing smoked! Yay! (y)
Put a 1kHz signal through the R channel - and looked at the output on my 'scope ... a lovely clean sine wave. Then I put a 4R/50w load across the R channel's spkr terminals - the nice sine wave continued.
So the R channel is AOK.
Repeated this with the L channel:
* without the spkr load resistor connected - there was no problem; ie. a smooth sine wave on the 'scope.
* but when I connected the 4R resistive load ... the smooth sine wave on the scope continued - but I began to hear a very high-pitched whine (maybe 8 -10kHz?). So I'm thinking ... something must be causing an oscillation in the L channel - but only when the spkr load resistor is connected. But whereabouts in the amp circuit can this be?
Andy
First of all I would look at my mosfet connections....I don't trust that type of Molex type connections....I have also seen point to point connections on to ONE mosfet? (filter 47Ω+220pf) ? Blurry image... look for loose connection......etc reduce mosfets wires .. ..increase the resistors gates ...all these with gen and scope..
Reactions: 1 user
Andy,
Nikos is on the right path I suspect. I also see a point to point method of attaching the snubber circuit for the Mosfets…in my honest opinion, the pcb that X sells is a much more optimized option with the snubber circuit, gate stopper, etc…all intrinsically attached to the respective pcbs. Long leads from the main pcb to the Mosfets is always a risk for possible oscillation unless a properly designed and implemented snubber circuit is included.
Good luck!
Best,
Anand.
Thanks for the suggestions, guys:
Andy
Andy,
I also hate those Molex connections with a passion - but, having soldered the pins to the PCB ... I think they're gonna be very difficult to remove. :(
Anybody have any suggestions as to the best way of going about it?
Also, if it is oscillation ... why am I seeing a nice clean 1kHz sine wave on my 'scope screen? Surely, I should see the oscillation on the screen?
Maybe I need to try a 10kHz input signal?
And why does it only happen when I have a spkr load connected - ie. I'm drawing current?
Andy
Andy
How very interesting, Nikos; the email which diyAudio sent me, alerting me that you had made a post, was in Greek - yet the post appeared in diyAudio, in English! o_O
Do you actually post in Greek (and diyAudio translates it for you)?
Hi Andy
Doesn't translate Diyaudio for me.....
English is not my native language...I edited and corrected it in English.
I had previously done a copy paste from Google translate to be sure that I am not writing them wrong....
Aah, OK. (y)
(Unfortunately, my Greek is only at the stage where I can read what you wrote (in Greek) ... but I can't understand what I'm reading. :( )
Reactions: 1 user
Hah - problem #1 (hearing a high-pitched whine on the L channel, with a 4ohm load connected) ... seems to have gone away. Amp is now silent (both channels). Verry strange - but welcome! o_O
But problem #2 has now appeared; this is ... the red clipping LEDs never go on (both channels)! :(
This is with the 4-ohm/50w load connected - and a (top-) clipped sine wave showing on the 'scope screen. The red LED is supposed to come on a couple of volts lower than the clipping voltage - at least, that's what happened when I did the "power output" testing, when I first got my amps working, in 2021.
I've tested both LEDs with my Atlas DCA75 - and they both show as 'working'. And I have the LEDs connected the right way, on the PCBs (cathode on the outside of the PCB).
Can anyone offer any suggestions as to why the LEDs are no longer functioning as clip indicators - iow ... what components should I test, to make sure they're not blown?
(Could it be anything to do with the fact that I have changed the NPN Mosfet (FQA40N25) to a Darlington (2SD2560), on Hugh's suggestion ... for added 'slam' and impact?)
OK, after some helpful emails from Hugh, I can now confirm that the fact that the red clip LEDs now never go on ... is a result of the swap from a NPN Mosfet (FQA40N25) to an NPN Darlington (2SD2560) - for the 4R build, anyway.
So, @xrk971 ... can I suggest that if you run out of your current batch of 8R PCBs and need to produce some more - it would be very helpful to first alter the circuit slightly (and therefore the PCB layout), to allow the same 'clip circuit' to be attached to the PNP Mosfet. This would enable builders of the 4R version to decide which output device they would prefer to connect their clip LED to. (This is influenced by the load provided by their spkrs.)
Reactions: 1 user
Please tell more about the Nmos to Darlington swap Andy/Hugh.
Is this change specifically for the 4R version? Would there be a difference in the standard 8R build?
Thanks🙂
Hey Vunce,
Substituting a Darlington for the Nmos (ie. only on the +ve rail) delivers more 'slam' and impact according to Hugh. And it's not just specific to the 4R version.
After having made the change, I thought that this was true ... but of course, it might just've been self-congratulation! :D
I seem to remember I had to fiddle around with one res value change (but I've forgotten what) - and of course the Darlington doesn't need a snubber PCB.
Sounds like this could be an interesting experiment, thanks for the info Andy🙂
Hi Vunce,
I've just looked up old emails I had with Hugh re. the res value change.
R133 on the 8R schematic (the Grid stopper) is 100 ohms; I had to reduce that to 22 ohms.
Hugh also said that the 8R circuit may not suffer from the "red clipping LEDs not working, with the Darlington" as much as the 4R circuit does. So you may be able to retain that function after you change over to the Darlington?
BTW, the Darlington is the 2SD2560.
Good luck,
Andy
Reactions: 1 users
