audio switch/bypass ?
hi all,
I need a bypass selector for:
a PiDAC that can send signal to the denon amp input directly or via a tube preamp.
I have searched in the forum and I've seen a solution with a switch discussed (for input selector thought).
a) All signals are line level, is interference a problem?
b) what sort of switch design do I need? Specific switch?
c) any usable wiring diagram? should I fear ground loops etc?
Your question is difficult to understand: a single audio source to a single audio amp; I don't see why a switch/selector is to be used. For bypass the tube preamp, a simple single pole double way switch is sufficient, a double pole for stereo usage.
Ok that makes sense. So for line level audio signals there are not “quality” problems (like interference) if you play with pole switches.
My plan is to have a tube preamp sometimes on the signal path, sometimes “clean”.
To be clear, I was hoping Osvaldo might post a diagram to show how to connect his proposed simple switch.
If not, I may attempt a diagram tomorrow. My solutions are 2 poles per channel or 1 pole and use 2 inputs on your main amplifier.
Otherwise, I have your DAC connected the main amplifier input while still connected to the pre-amp input; which may or may not be a problem.
This is the suggested lay out. Not to complex to understand, certainly.
I assume then the high impedance tube input does not affect the signal when pre-amp is bypassed. Might be a different story if a low input impedance pre-amp.
If your main amp has source selection then no need for the switch.
Just an RCA splitter per channel.
