DAC AD1862: Almost THT, I2S input, NOS, R-2R
Joined 2019
With a proper quality transformer with blind winding between primary amd secondary, and with magnetic shield, it shouldn't be as critical. BUT, properly done toroids are scarce so i'd follow the advice above. We are lucky there are amazing toroids from Trafomatic here in Serbia.
Reactions: 1 user
Joined 2009
Has anyone done any tests to see how distortion varies with the value of Riv for the ad1862?
TDA1541R1 example, courtesy of mvlabs:
Reactions: 1 user
Joined 2019
Friends, I'm studying hard the thread.
Naive question: is there a way to make only one build, and make the dac switchable between ad1862 and tda1541 simultaneous mode?
Really my wife is going to kick me out if I build 2 enclosures this time
Joined 2022
with all the various power supplies for each DAC ...... and their transformers.... your single chassis will be as big as two smaller chassis :ROFLMAO:
Joined 2019
Hey colleagues, please show me some lineage!!! Of how your CD players, TVs, raspberries and Nas are plugged to this wonderful dac via USB, spdif, coax!!!
Trying to figure out how to put it ad good use apart from my old CD player!
PS. I've a qobuz sub now, I'd like to use that with this dac!
Joined 2019
Another thing I can't understand is about the CPLD converter... Is it needed with the ad1862? I understand it is needed for the tda1541 in simultaneous mode, yet I can't see the boards in your ad1862 build...
What would be its function with the ad1862?
Joined 2014
You should start at page one of this thread with a notebook and pencil ready for note taking, there are many, many builds and tons of pictures showing how diyers implement the AD1862 chip plus several others. Go to the Electrodac link Miro attached in post#1, all the info you need to start is there. Download and read the AD1862 datasheet. 😉
Reactions: 2 users
Joined 2010
DAC702 prototype schematic 😎
Glue Logic piece ... at least in simulator it works :scratch2:
I2S 64-Bit Sample Glue Logic for DAC702 principle (bipolar output) in theory:
  • 15-Bit serial data delay for sample aligning with the LRCK rising edge* (IC1, IC2)
  • 16-Bit serial data delay with parallel out buffer for DAC1 (IC3, IC4)
  • 16-Bit serial data delay (IC5, IC6)
  • 16-Bit serial data delay with parallel out buffer for DAC2 (IC7, IC8)
  • Inverting each MSB of the I2S code to get COB code (offset binary) for bipolar output (IC9, IC10)
  • *LRCK rising edge is latching aligned data from parallel registers into DACs
Reactions: 6 users
Joined 2018
Guys, I buy arduino nano and oled display for her but I don't get it how to connect arduino and ours Dac? - There is a mention about LRCK pin on Dac but it needs to be more pins from arduino. Who can help with connection? The code is he:
DAC AD1862: Almost THT, I2S input, NOS, R-2R | Page 370 | diyAudio
I want to see the info about sample rate on display. I need for the Jlsound and Amanero transports.
Thanks!
Joined 2010
@sworder84
Display is connected on fast I2C output from arduino nano (pins SDA (A4) and SCL (A5) ... plus voltage and gnd pins) ... check if your display is for 3.3V or 5V power supply.
LRCK is connected on pin D2. GND from DAC must be also connected with arduino GND.
  • DAC_Sample_Rate_LRCLK_OLED.rar
Reactions: 1 user
Joined 2022
@gsrchrisu, if you are referring to using programmed CPLD converter as created by Miro for TDA1540 and TDA1541, yes it is meant to replace the glue logic section for simultaneous operation.
Reactions: 1 users
Joined 2005
Anyone tried AD1862 in multichannel configuration. As I know there is only a few USB-I2s multichannel boards
1.https://www.minidsp.com/products/usb-audio-interface/mchstreamer
2.https://www.diyinhk.com/shop/audio-kits/142-2302-xmos-multichannel-high-quality-usb-tofrom-i2sdsd-spdif-pcb.html#/67-xmos_firmware-192k_8ch_out_8ch_in_spdif_out/111-usb_cable-null/141-fifo_option-null
Top
