Room acoustics and the quality of the software
What do you mean by software?
Leak SandwichMostly British stuff.....
The quality of the recording. But it does not mean it has to be a special recording. It has more to do with the basic recording technique. Over the years I have discovered some cheap (vinyl) records that simply sound great. I have not done it with digital stuff.What do you mean by software?
Not so old. I actually never had the possibility to listen to that. Mostly from the 90ies or early 2000s.Leak Sandwich
I'm interested in building some sort of single-ended triode tube amplifier, probably in a mono power amplifier format. I know enough to know that 15W is a lot to ask of a SET amp, but not enough to know how feasible or infeasible it is. If my expectations need readjusting, then please, adjust away.
Thank you! I knew there was something I wasn't remembering.
I could probably make 10wpc go if I bi-amped. How complex is a 10W mono design?
I'm not a fan of old speakers, but if you have the opportunity one day to listen to leak sandwich 600, go for it without thinking, it's really a joy.Not so old. I actually never had the possibility to listen to that. Mostly from the 90ies or early 2000s.
Finally, some sanity... ;-)NVM, you're right. The only path to decent sound is via 1000V on the plate transmitter tubes...
But I prefer 2000V...
Once I realized this, my life became simpler.Measurements are necessary.
Studio Room, instrument or voice, microphone, recording equipment and post production equipment, playback device (CD, cartridge, etc.), preamp, power amplifier, loudspeakers, Ear(s), and room.
Starts with a room; ends with a room.
