Hey,
I'm trying to install firmware and a dsp file onto some new Hypex Fusion amps. I was able to install the amp firmware but have been completely stonewalled on installing the dsp filters. When I open the HFD program I can see the correct amp firmware is loaded (version 5.7 for a FA 252) which if I'm understanding it correctly then requires a separate download to install the dsp filters? Problem is when I select the firmware update window the necessary file isn't available. I'm not used to using windows so maybe I'm not downloading the dsp files correctly? At least not storing them in the correct location for HFD to recognize? I've been banging away on this and have yet to get it right. This is probably because I'm unfamiliar with windows and hopefully is an easy fix?
Please advise if you can help
