plot B vs Ic with SPICE
Joined 2002
Try to be specific.
Hi ,
What is B and what is Ic ( current I presume).
Where do they come from and what do they represent?
Either try to explain to make the situation clear or post the circuit diagram ( much better ).
Without this you will probably get no reply from anyone!
Cheers.
Something like this:
Joined 2002
Hi Gunderz,
I get it now. However I can't help you.
You seem to be in an enviable position to be able to spend time plotting out such things. I can't get enough time to simulate all my circuits let alone try out the real basic plots like forward gain against Ic.
I just look at the spec sheet. No time for anything more than that. Lucky you !
Cheers.
