Load this T-TQWT into HR, capture current results, then copy the record and change the driver from TH to ND and compare captured to see the various differences of each window: https://www.diyaudio.com/forums/att...vity-designs-t_tqwt_chambered_lab15_input-jpg
Then try different driver offsets and lengths in the LW to see how it affects each and once you get a 'feel' for the major differences maybe any 'loose ends' can be dealt with much more specific Qs.
GM
GM
