Yet Another Aleph J Build
:cuss: making me think!!! How about pointing me toward a schematic of the version prior to this?
I described the differences here including some of the design topology:
So a little word on some of the technical differences between the two designs. It's very easy to see that ZM has tightened up his version particularly in a more compact layout, use of cascode regulation for the input JFETs and finally some current sources. The output stage uses the Aleph CCS but with IRF 150's which provide intrinsic matching! As such it is a much more turnkey method of building an Aleph J. There is no need for matching the output devices whatsoever.
Best,
Anand.
  • Thank You
Reactions: 1 user
Official Court Jester
Joined 2003
as it seems you didn't post it, here it is, schm of built one
  • Thank You
Reactions: 4 users
Joined 2006
Are you sure that that maters? When I tighten down the screw hold downs on the euro blocks the ferrule is flattened.
It may not in practice. But they are made for that purpose and I have both so I haven't tried. But still likely much better to use hex in square block than bare wire.
Reactions: 1 users
Joined 2011
I agree with the sentiment ferrules are the way to go. Bare wire works but ferrules stand the test of time better. when you look in most control consoles for CNC and like machines they use ferrules all the time to complete connections.
Joined 2023
Interesting. A class D guy, arent ya?
Don't have anything against Class D, but.... For all I know it may be more accurate than A or AB, but the models I've heard to date lacked a little meat on the bones in the mids. I would comment that most early SS designs were kind of hard to listen to, so maybe w/ continued development???
Joined 2023
Ahhhhh. Listening to Sarah McLachlin, Mirrorball, she sings so sweetly as does my Aleph! I was going to post 1 of her videos but couldn't decide which one.
Reactions: 1 user
Joined 2023
Just powered up my Aleph and had a hum through the speakers, not 60Hz, very similar to my SuperNait 3 if it has an "inductance" hissy fit. Powering down, briefly, no effect. Remove the left channel RCA and that channel stopped, did the right, same, re-connected and it's gone. There is 1 other difference in the system, yesterday I connected MFF RCA's and connected my sub.
Top
