For years I have been using Foobar2000 on Windows 10/11 into Cantabile. This host several VSTs, to work as a 4 way crossover / DSP.
The audio then goes over USB into my 8 channel DAC, followed by nice hypex modules to drive my DIY speakers and 2 subs.
I love Foobar2000 and use Windows for my work, so I would like to have this stay my primary PC, and the way to play audio.
But I would like to offload this audo processing to a separate laptop running CamillaDSP on Ununtu or Debian. To try, for fun, to tincker.
No problem, I figured.
But then I got stuck: how do I get the audio from the windows PC into the CamillaDSP laptop?
The laptop does not have a digital audio input. Does anyone know of a software solution? Eg to run the audio over ethernet somehow.
Of course there is Dante. The AudioOverIP stuff seems much too complicated and expensive for my use case.
I also came across SonoBus, which is available for windows and Linux. It is open source, which I like, but is looks more geared towards multi-user cases and don't know if it will connect to CamillaDSP (I'm a complete Linux-noob).
But there must be a simple (and cheaper!) solution I'm overlooking?
Your ideas would be appreciated!
Btw: does Ubuntu natively support a USB XMOS UAC2 DAC? Or does it need drivers?
Thanks for the ideas.
Upnp is quite a hassle to get it to work 100% in my experience.
I thought it would be a good use for an unused laptop. USB gadget mode would be ideal. But no chance of getting this to work on a PC I guess, at least for me.
https://www.collabora.com/news-and-...-and-how-to-integrate-it-with-systemd-part-1/
This is way over my head.
Did you see this thread:
https://www.diyaudio.com/community/...th-camilladsp-from-a-desktop-computer.396043/
Seems to be the sort of solution you are seeking. It's also the level of complexity you can expect. There really is not a simpler solution than using USB gadget mode under Unix but unfortunately I think that is still mostly broken on the Windows side...
@CharkieLaub, thank you for looking into it!
The poster has Ubuntu on his main pc though. I have to use Windows for work on mine.
Maybe Pulseaudio would work under WSL linux subsystem in W11, but I'm not versed enough in Linux/Ubuntu to troubleshoot the inevitable problems.
I did not find it hard to get a uPnP render working on a Rasp Pi using "upmpdcli".
https://www.lesbonscomptes.com/upmpdcli/
It streams audio perfectly into CamillaDSP.
It also handles volume control so the volume can be controlled from the uPnP Control Point on my phone (HiFi Cast)
@marcelooms If you are looking for keywords to search, try RTP streaming. There are programs like FFMpeg that can do this under Windows:
https://trac.ffmpeg.org/wiki/StreamingGuide#Pointtopointstreaming
I have had success before using FFmpeg and DirectShow capture to get Windows audio and stream it. Then I used VLC on the RX computer end to receive the stream. Going the software route would take some work to get it up and running and learn about these programs, etc. It sounds like you are seeking something that is more "plug and play" for the connection between the two computers.
If your Windows box has SPDIF output you could purchase a USB SPDIF receiver from Amazon like one of these:
https://www.amazon.com/Cubilux-Receiver-Interface-Suitable-Dell【ONLY/dp/B0BQQLFQ59/ref=sr_1_3
https://www.amazon.com/dp/B0BQR2YZPT
that is advertised as plug and play under Linux. It is capable of 48k/16-bit max digital audio. You would need to run an SPDIF toslink line between the two computers, but this might be a simple solution for you.
Please do you have any more info? I have not heard of any issues since kernel 5.18, maybe early 6.There really is not a simpler solution than using USB gadget mode under Unix but unfortunately I think that is still mostly broken on the Windows side...
@phofman Are the Windows-side gadget issues fixed now??? I have to admit it has been a while since I have looked into it, and at the time it seemed that the Windows devs were not taking up the issue to do anything about it. Everything was working well between Linux machines, but IIRC the gadget (e.g. Pi) could only operate in at one fixed sample rate and possible bit depth when interfacing with Windows. Has that been resolved now?
If the Windows issues are fixed it would be fun to do some experimenting with the Pi5 or a mini PC as a USB gadget DSP DAC/crossover.
Since 5.18 the gadget can offer multiple samplerates, as configured. Since the feature follows standard UAC2, it works fine in windows too.IIRC the gadget (e.g. Pi) could only operate in at one fixed sample rate
The gadget does not implement multiple altsets yet, and offers only one bit depth, as configured, to any OS. Multiple altsets have been discussed recently, will take a while to implement https://lore.kernel.org/all/CAB0kiB.../T/#m8b40ff8ce53fe701a1fe6a76c119a1438b45037fand possible bit depth when interfacing with Windows.
- PC Based
- Easy way to get audio from Wwindows into a separate Ubuntu PC running CamillaDSP
