Post your Analogue Source pics here
This is my bid to earn a 'sticky' thread. My first attempt at a Pre-amp. It's dual-mono throughout. The RIAA is all-BJT based off the famous NAD3020 circuit. There is an all-BJT shunt regulator based off Salas designs. And there is a cathode follower output buffer loaded on an active 'amplified resistor'. Haven't tested it yet, but this thread is for piccies :D
Nice work Gareth!
Please post details;)
Phonoclone with Salas shunt regulator
Thorens TD850 with SME309 tonearm
plus DIY motor power supply and motor base
Hello,
your DIY gear are great !
I add some of my DIY gear:
DIY Le Pacific JFET RIAA;
DIY OBH 8 SE RIAA;
DIY inDiscreet Phono
Pulse circuit for strobe LED (you see clear markings on platter instead of blurred )
External PSU for DD motor.
All my DIY RIAA together..but I think that there will be another - addiction ...
My latest project completed...
Rek-o-kut lp743 turntable
Rabco sl8 arm rebuilt by Dave Shreve
I took the motor apart and scrubbed out all of the gunk. Motor mounts were replaced. It runs so smoothly that you cant hear the motor while holding it in your hand.
Phono pre, MM, MCHO, MCLO.
Variable gain, C load, R load.
2 riaa eq: passive, active; passive.
In/out rca, xlr.
PSU: dc filter, AC cmc, solid filtering RCLC, 4 superregulators.
1X9csvbaWZoBBqDRclvhH29TPVihAKgtmmunX7bmhmPn6USpGitKHDcOHIXaQLX7R9WodLkwA-cn=w848-h636-no
Once again ...
Yeah !
Muffsy PP1 (Audiokarma CNC)
You have a lot of RIAA amps !
Ahaja - wow, very adventurous - love what you did with the dip switch selection tables on the top panel :)
