Omicron, a compact headphone amp with -140dB distortion
Joined 2004
Another Omicron up and running! Unlike many of my builds that remain "unchassis'ed" (part lazy, part lack of skill, part "on to the next thing"......!) I went ahead and buttoned this one up. Sounds really good! Dead quite! Just started messing with Raspberry Pi, DAC HAT (ProtoDac) and streaming. THANK YOU to Alexcp for sharing and making boards available! I post even less than I fully finish projects (diy thing I guess?) so hopefully I have not screwed anything up? High time to participate and more importantly THANK the greater diyaudio community for all the knowledge, willingness to share, help, and inspire! Not possible without this community! THANK YOU!
Ed
Reactions: 5 users
Ed,
I really like your case, I was going to use the same technique. I am glad you did it and it works, and looks great. How did you bend the aluminum? Last time I bent it I had to cut a groove on the backside, was a little difficult to get table saw depth just right.
Bill
Reactions: 1 user
Joined 2004
Thanks Bill!
Full disclosure...............I cheated! Here!
I thought it was a fair price for the the amount of time and effort for sourcing, bending, cutting, and potentially/unnecessarily screwing that part of it up. Fit and finish of the pieces/parts as arrived were fantastic. I did my best not to butcher my part. It was very easy to cut, drill (stepped bit for larger holes), counter sink and it is built like a tank. The bottom/top plate I had to cut length-wise to fit into the recess as it overlapped the width? I didn't like the look of just all aluminum top so I veneered with some scrap I had laying around. My cut was not perfect so there is just a slight gap but it allows some of the LED light from under the hood the shine through and I think that is cool? Volume knob is a "ribbed" juice bottle lid that I epoxied in a traditional volume knob. Drilled a small hole for the set screw access and epoxied in nuts and bolts to add weight. Added the matching veneer and now it almost looks legit.....don't tell anyone it is a cheap juice bottle lid!
Ed
Reactions: 2 users
Ed,
Very creative, I love seeing solutions outside the box. Helps open my mind to alternative solutions. Just soldered up smd version , was putting it off but turned out quite fun using hot air. Mouser shorted a few parts so will have to wait to finish up. Case will accommodate my hiby docking station on top of it, trying to tidy the nightstand.
Bill
Reactions: 1 user
Electronic circuits don't have sonic anything! You have to be careful with SMT parts, for instance thin-film(*) resistors are required for low-distortion, and its best to choose larger sizes even so. Polypropylene (PP) and polystyrene (PS) caps aren't available (they melt in a reflow oven), so you probably want to pick PPS caps which are reasonably good performers. Surface mount can be much better thermally BTW due to heatpads directly soldered to the PCB - with multilayer boards in 2oz copper the PCB is an effective heatsink.
Is SMT metal film is called thin film, and metal oxide is called thick film, just to be confusing.
Joined 2009
you had to lower the bias on the smtp version.
It's more like the TH version can have much higher bias if needed, esp. with taller heatsinks, while in the SMT version is limited by the heatsinking provided by the PCB itself. Stock TH runs at about 50mA (with 100 ohm resistors), while SMT runs at about 25mA.
In principle, the lower biased output stage would leave Class A sooner with large signal peaks and a low-impedance (32Ω) load. Class A ends at twice the quiescent current, so for the SMT board with its 25mA, that would be 50mA, or 80mW into 32Ω. With a typical can sensitivity of 100dB/mW and a normal listening level, that would happen from time to time, but not very frequently. However, Omicron stays very, very linear even when that happens (see the bottom of post 11).
In practice, I find it hard to hear any difference even with my 32Ω Grado GS1000i.
That's true, and the BOM includes all the right stuff. Only thin film resistors and NP0/C0G (white-blue, not brown) capacitors in the amp proper and MKP caps in the crossfeed circuit. The protection circuit does use brown 1uF X7R caps, but these don't matter. Also, quality, low(ish) ESR electrolytic caps are recommended for both TH and SMT versions - but nothing exotic; the prototype uses Panasonic FC throughout.
Reactions: 1 user
Joined 2009
if is it possible to buy the pcbs, parts, etc. in a kit
Not at the moment - unless someone wants to part with the boards from an earlier GB and put together a kit for you.
In a way of explanation, Omicron (at least its through-hole version) was designed to be inexpensive and simple to build with garden variety parts, most of which you probably already have, and the rest, easily obtainable from the usual sources.
murata 78602/3MC
78602/3JC is a direct replacement. Other 1:1:1 transformers from the same 78602/xJC series should work. As a last resort, you can probably wind your own on a ferrite core - I have not tried, but why not? Wind with three wires simultaneously and use each of the three as a separate winding. You don't need many turns as long as the leakage inductance is in the hundreds on nH range.
