Where are located? I may have a pair stashed away if you’re in the USA?AX14 it is! Are there any preferred PCB houses I can go too that might already have the PCB on file?
You must test preamp with amp connect to output, amp input impedance load preamp with 22k... P30ZF DC offset is very good for circuit without global negative feedback.
Hi Sir all This Gerbers Fully tested and WorkingHere you can order a pcb Apex-14:
https://www.pcbway.com/project/shareproject/Apex_AX_14_2.html
And here you can order Apex-17. Also a good amplifier.
https://www.pcbway.com/project/shareproject/Apex_AX17_amplifier.html
I collected amplifiers on these pcb.This Gerbers Fully tested and Working
Prasi also did a layout of this amp in both mono and stereo.Hi,not sure how to navigate on here ? But can someone help me try and find PCBs for
FH9HVX apex amplifier as a relative nieve builder of amps thanks to anyone who can help
Thanks For response seems Dual layerI collected amplifiers on these pcb.
Yes, the pcb is dual-layer.seems Dual layer
Dear Sir please Share with me my Email address issure PM your e-mail and I'll send it to ya no problem yes I called "Golosa" but is just AX-14 with more pairs
Best Regards
Juan
Hi Sir Can you Share PDF for home Eatching
