Last, but (hopefully) best ever modified and complete NAD 3020
Joined 2021
So I've finally finished making the heatsink
Reactions: 2 users
Joined 2021
@Protegimus ,I made it from scratch, so I'm pretty pleased with it.Power supply is OK, it's the caps that flounder. They are 35v,but I measured the voltages and they do lag behind a bit if you have it switched to the higher rail voltages, so I use either 50v or 63's and that seems to do the trick
Reactions: 1 user
@poundy I have been following your thread for a while, and I'm learning a great deal from it, thank you for sharing!
I have a 3020 that's been in the family since new, about 1982/3
I recently bought a 3020A for 300ZAR (±£13) no cover, no base and very dirty. I am in the process of getting it back to a working condition and upgrade, hence the interest in your post. At this point I am stuck, needing an RCA MJ2955
Anyway, do you want to share the list of caps that you replaced? Will really help me if I get this one sorted.
John
Reactions: 1 user
Joined 2021
@inphase01 ,i did a full recap of the electrolitics, replacing some with film caps. I do have some original RCA(H) MJ's but it looks like you are a long way away.You realy need matching pairs. If when fitting these so you may be batter off changing all 4 and get matched sets. I always fit emitter resistors to the H's as well. What is the serial number of you amp?
I am really keen to take the RCA's off you if you want to sell them. I have family in the UK and my brother-in-law will be visiting there next week for 3 weeks. Maybe we can make a plan? The serial No. is B3224084
Joined 2021
John
I just havent put it back yet
Joined 2021
ok so that is a realy late one, just before the 'b' version and will have the board represented in these 2 diagrams
Your phono and power amp set up will be as diagram 1(3120)-your tone sections as per the next diagrams
Ive never been able to find an 'A' version manual so ive had to work it out working on various versions
The series 20 original had 2 setups basicaly, the late ones having the 'A' board but without the MM/MC circuit
The 'A's a combination of below and the B's a slightly different set up and power supply
Ive just checked my transistors and i only have NPN's no PNP'S sorry
you best bet is to buy these, ive used these and they are from a good supplier-if you buy a pair they will be batch matched
https://www.cricklewoodelectronics.com/2N3055H.html
https://www.cricklewoodelectronics.com/MJ2955.html
dont be tempted to get from ebay
good luck with your work(y)
Joined 2021
So the heatsink is finished and I've changed the right hand foot to encorporate the grounding connection. I made 2 small plates to screw through to from the foot plate. Now I'm about ready to start modding the transistors
I will trim the screws etc once I'm 100% happy I haven't got to alter anything.its taken alot to get to this point, but rather satisfying to see the end result so far
Reactions: 1 user
Joined 2021
so ive come away from dropping them straight through each hole and swapping them over on the board.I didnt want to destroy it, but leave it in a way it could be put back as it was.
so the gate stopper is connected directly to the FET Gate and then i have a wire on each of the source and drains.This means i can cross them above and solder 3 at least direct to the original connections on the print
