I've only seen what you are asking for in BJT although my experience is very limited. Soundstream used something like you are describing in their older car amplifiers, which is a 6-pin package with two independent, yet thermally coupled, BJT's.
https://www.onsemi.com/pub/Collateral/BC847BPDXV6T1-D.PDF
Something like the above only with two P-ch fets similar to BSS110?
The only actual matched dual MOSFETs that I know of are those made by ALD. They are all low-voltage parts though, not like BSS110.
Thank you friends for spending your time.
For jkrokenberger: sorry, I need 2 P channel MOSFets, not a NPN-PNP pair
For Mr Evil: I checked ALD website. There are 2 things I don't like:
1. the devices shown have a low VDS voltage, about 10 V;
2. the output capacitance is too high in comparison to BSS110
Anyway, at the end, I was able to find the BSS110 in SMT version. The P/N is BSS84. It is produced also in a dual P channel version. Its P/N is BSS84DW from Diodes Incorporated https://www.mouser.it/datasheet/2/115/ds30204-88131.pdf
Thank you very much for your kind and precious support
Milo
Milo
