Found another Precision Power A404. Noticed this one has different PS FET's and PS resistors than my other one has. My other one had SMP25N06 FET's with 100 Ohm resistors. The new one has MTP50N05E FET's with 47 Ohm resistors. From what I can tell from the datasheets I've found it appears the IRFZ44N's I originally asked about are a close match to the MTP50N05E. Would in fact the IRFZ44N be a good replacement for the MTP50N05E? Or should I use IRFZ44PBF as I used in the other one? If so, should I then also replace the 47 Ohm PS resistors with 100 Ohm resistors?
