For Sale - Massive 6 Channel Amp based around the LME49830 chip from TI/National.
I designed and built this myself several years ago, and it has served me very well, and been totally stable. I wanted something with excellent performance and not power limited. In total, the amp should be able to do 700W continuously, and possibly 200W peak on a given channel, but I've never driven it anywhere near that. I'm selling it because I don't need this much power anymore, but rather the space...
It has a separate power supply with +/- 54V rails. The transformer is 1200VA, and massive, with 50,000uF of capacitance on each rail. In the picture, the upper box houses the amp modules. In total, the whole thing has to be about 50lbs. The output transistors are matched IRFP FETs. The heatsinks have virtually silent fans on them and barely warm up under normal conditions.
Here is my build thread: http://www.diyaudio.com/forums/chip-amps/132179-6-channel-lme49830-power-amp.html
Previously, I use this with a miniDSP system (now removed), which is why you see only two input connectors. Internally, each module has its own two pin board connector, so you will have to do a little wiring to attach this to whatever you use it with. I recommend that only people with some DIY skills buy this, as you will probably have to tailor it to your situation.
I'd like $300 for it, which is far below my parts cost. I'm in the Los Angeles area, and reluctant to ship it, as it will be complicated and costly. The best way to contact me is at peglegpatrick AATTTT gmail DOOT com
