Nigel Wright's Vendor Thread
http://www.murtonpikesystems.co.uk
PCB design software Condition is "New". 2023 version.
Download and software key (no CDROM needed.)
Why is a download better than a CD ? you can download newer versions as they come out.
Runs on Windows XP (SP3) , Windows Vista and Windows 7, Windows8, Windows 10 and Windows 11.
This is a mature product with no bug list, if I find a bug it is fixed immediately.
Support for this product is second to none, you are supported by the guy who wrote this software.
Schematic and PCB symbol designer wizards.
Auto creates SIL, DIL, BGA, circular and QUAD PCB footprints from your parameters.
Schematic entry with auto convert schematic to PCB rats nest, unconnected pin scanner and single ended net scanner.
PCB entry with 127 layer rip up and retry auto-router with clearance and continuity check.
Gridded and grid less auto routers.
360degree rotations of pcb components with obround pads.
Integrity checker, compares schematic and PCB for differences.
Component locater.
Parts list output to file and to printer.
Schematic/PCB component auto-renumbering and re-annotation.
RS274X Gerber file generator and NC/Excellon drill file generator.
Pick and place file generator with fiducial option.
3DPCB viewer module. (for this software output only)
Output schematic to printer auto-sized.
Output PCB to printer in 4:1, 2:1 and 1:1 scaling, inversion and mirroring about x and y axis.
Merge schematics and merge PCB's.
Library scanners for fast component selection.
Gerber file viewer (for this software output only)
Component locater, block-mode for repeats, shifts, rotations etc.
Net optimizer for shortest routes.
Auto component placers for minimum routing.
Recursive auto-autoplace, rotational autoplace and swap autoplacer.
Auto-place and route recursively function for lazy PCB design.
Unconnected pin scanner.
Forward annotation function from schematic to PCB.
Screen capture to bitmap file in schematic and PCB entry.
PCB's up to 50 by 50 inches.
127copper layers.
127resist layers.
Copper pours, each layer can be connected to a different NET.
Two silk layers (upper/lower)
Comes with basic symbol libraries, 4000, 7400, smd4000, smd7400 and general as standard.
User manual in each module
This is the full version and not a crippled, time limited or downsized version.
This is a fully integrated package and not a suite of amateur free programs cobbled together.
Fully supported package with email and phone help lines.
HI Nigel, was wondering if you might have some details about this amp board I was gifted. I know its old, but I was hoping to make a powered sub out of it.
I found I often edit the pcb tracks and was forever typing in layer 1/2 and width 80.
I have now added control-a to make track up to next pin layer 2 and width 80.
Added control-d to make track up to next pin layer 1 and width 80.
Added control f to make track right angled to next pin even if pins are off grid.
Added control b to make tr5ack aligned back to previous pin even if off grid.
