R2R Shunt Volume with 3 selectable sources
This design:
http://www.audiodesignguide.com/VolumeNew/index.html
HQ-R/2R VOLUME Technical Specifications:
Specifications:
– low tolerance 0.1% R-2R network with melf resistors
( resistors in parallel produce a pure resistor).
– attenuation in 64 steps - each step 1dB
– Input resistance ranges from 20k to
47K for a Rload of 47K.
– Output resistance ranges from
22K to 47K.
3 selectable inputs with option to edit input name
– one direct input
– display back-light programmable On/Off - if Off timeout 10s
20X 4 display characters for wide view
– tube menu for delaying plate voltage
- 3-modules design: Powers Supply (PS), Control and Display Unit (CDU), Relay Module (RM) in SE or Balanced modification.
-Volume attenuation by rotating optical encoder or from IR remote control.
- Input selection by rotating optical encoder or from IR remote control
- Display auto dimming with adjustable brightness level
- ONE open collector outputs for power On/Off and tube plate delay
- Main AC power on/off control
– AC power consumption, Max. 6W.
Special : The avoidance of clicks is the major improvement with respect to my original attenuator design of several years back.
in most of the design volume -32db relay at transition to -31dB, the relay volume 64 steps are emitting huge sound in the speakers, causing discomfort, not safe for the system.
I definitely settle this phenomenon, therefore, very smooth transition Volume and sound great.
This link for Video of Volume: https://www.youtube.com/watch?v=s9QEZduZavs
this complete module assembled including the aluminium remote at 250$ + shipping.
thanks
please see some other designs:
The δ1 relay-based R-2R stereo attenuator
Audio Volume Relay Attenuator with IR Control
VC-03 Volume Control
Hi Jaffrie!
1. Understand that there's a power on delay build inn. What is the time frame & is this adjustable ?
The delay turn on for amplifier about 5s
The delay for the output about 10s
2. Possible to link the power on to power amp as well ?
yes, can use for your amplifier , but the relay on about 5A to 8A ( you can use other relay if your amplifier need big current )
3. What is the actuall price of the complete unit as I see $200 n $ 250
Price 250$ + shipping!
thanks
quanghao
