I would like to try increasing the 5.0 voltage (100 mA) supply to my DIYINHK AK4390. Reportedly increasing this up to 6.8 volts yields an improvement. I would like to try it.
Could anyone recommend a kit or readymade that I can buy. In the US preferably but from China would be OK.
I have an AK4399 on the way from DIYINHK and will try it on that if works on the 4390.
Thank you.
NOTE: I have a DIYINHK 7 volt PS but I would like to try less than that.
Thank you.
Thank you.
I VERY MUCH DOUBT it can "improve" anything and rising voltage 40% above Factory rating will at least abuse it and most probably damage it.
Lots of questionable to dangerous to crazy "advice" floating around in the Net.
Actually the I just found factory documentation that indicates that a voltage of 7Volts is OK:
" Power Supply: DVDD=AVDD=3.0 3.6V, VDD1/2=4.75 7.2V"
Under "Absolute Maximum Ratings" Max VDDL/R is indicated as 7.5V
https://www.akm.com/akm/en/file/datasheet/AK4490EQ.pdf
I will do a lot more reading before I try it but others on this forum have done it with good results and the manufacturers document appears to indicate its O.K.
